Hi Guys,
I'm from over in the Uk and have recently purchased an Autech Stagea, in quite standard form. It has a Nismo ECU and lots of other Nismo parts. Question is, what engine does the car have, is it a Nismo Block and turbos ?
How would I find out ? :D
Moff
Edited by Moff
https://www.sau.com.au/forums/topic/303449-atuech-stagea-engine/
Post up your vin no and someone may be kind enough to look it up on the FAST system
The Stagea 260Rs was built by Autech from standard RS4T off the assembly line. There was a smaller number of these made as Nismo versions with more power or you may just have the RS260 intowhich someone has added the Nismo goodies.
I've had a quick look on fast, but doesn't seem to give much info on the engine and turbo itself
wgnc34-105842
I had it dyno'd at 1 bar, managed 315 BHP hubs and 305 lb/ft (de-cat, exhaust and Panel filter) on a RWD dyno.
Is there anyway I can tell what variant ?
Stock 260RS's has R33 engine's, just normal 05U blocks, not N1's which is commonly beleived, they also only have stock 33 GTR turbo's.
Depending on the dyno 315 at the hubs is close on 1bar for stock turbo's etc.
Hi Guys,
Moff
Can you post up some pics? Never seen a Nismo Stag other than advertisements. Porn.
Cheers GW
I do not know if it is a Nismo version, that is what I am trying find out... Can anyone with an Autech confirm if their ECU is the same as mine ?
The number plate came with the car :D
Edited by Moff
Haven't got an AWD dyno?
Couldn't be stuffed ripping out the front shaft and fuse to make it run in RWD?
Don't stress!
Just jack up the front of the car with two standard jacks to get the front wheels off the ground and start your power run!
Can't possibly see anything going wrong here...
Don't stress!
OMFG.....ROFL....just realised....nah there not doing that are they... :(
BTW....love the RS260.....there an awesome wagon once you get em going.....still wish I had gone that way instead of the M35!
it's okay chassis dyno... Rear wheels have been removed and the hubs are actually bolted to the dyno...
Given that they advertise as Skyline specialists, I would imagine that this is farely normal for them...
http://www.mgt-racing.com/
To answer the original question, you've got an Autech 260RS that was sent to the Nismo Omori factory for Sports Resetting, which included and intake, computer and plugs. Think of it as a remap (a very expensive one, I might add) that gives you probably 30bhp over standard, but it's mainly designed to boost torque across the midrange to compensate for the thing being so heavy :(
http://www.nismo.co.jp/omori_factory/origi...m/sr/index.html
Quote "I do not know if it is a Nismo version, that is what I am trying find out... Can anyone with an Autech confirm if their ECU is the same as mine ?
The number plate came with the car "
Unquote
Thanks for the pics anyway moff, Nice wagon! Looks just like mine used to..........only much cleaner. The reason I wanted to see a pic btw is the Nismo jobs have a different grill, same shape as de pulsar gtir. Or at least the pic I have seen did. Would be able to tell straight up if she was the Nismo version in that case I reckon. No doubt others will disagree but my 2c.
Cheers GW
Just changed the cat to a de-cat, and it was a racing cat that was in there.
You guys are right :blink:
So far it seems, ECU, racing cat, induction kit are different.
Does anyone know of any other differences I should look for ?
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
