  • Replies 846
Posted Images
Spewing I missed out on this one - I'll check my work commitments but should be able to help out if required. Oh and adding a shameless plug - anyone needing track rims and or tyres check this out - deal of the century!!!
Genuine 1min15 @ Mallala tyre and wheel package :-)
I'll put you on the reserve list Andrew, you might get lucky :P
Thanks Luke - I don't want to cause a sh@t storm over not being an SAU:SA member though. In the future I will probably join, its just I am currently a member of both the porsche and GSR/EVO club. Happy to help out if that is all I can do.
so Andrew if i buy your rims and stick em on my Camry ill get 1:15 around mallala, sweet :)
do it steve, u kno u wanna
pity i cant fit them on the patrol, she'd be the quickest diesel GQ known to man :bomb_ie:
********News Update*********
Don't forget we will be selling raffle tickets @ $5 a pop for your chance to win a secret spot in the up and coming SAU track day, buy 1 or 100 SAU: SA picks up the tab for your entry fee, you still have to supply your fuel and cams license,,, GOOD VALUE!!!
Hey Luke. I won't do this one, so I won't need to be on the standby list.
Car has atleast got a couple more months in the build to be ready. If it is ready I'll come for the drive and help out where I can.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
