  • Replies 846
Posted Images
If it is my turn in line - I guess I'll say yep.
:( will be there to see this thing in action again.... last time i saw this on the track it was like a limping t rex.... an animal pulling 1:14-1:16! but ive heard alot ahs changed!
Is it wrong for me to want 4 people to drop out so that I can see, hear and compare with Blue32's R32 GTR? :D
Jugs had to pull out of this event, just got the news now. Dohmar, you're up
EDIT: Dohmar said no, Blue32 is up
*sings*
"When you wish upon a starrrr,
Makes no difference who you arrrrrre" :banana:
hahaha itching to get on the track David
Definitely.
Considering going to the open day at Mallala on the 27th.
But I'm still dirty at Santa for not giving me a big brake upgrade kit. If only I could find $10k laying around.
Definitely.
arent we all.....i am trying to get everything sorted out before i fly to fiji at the end of march.....one month to do almost everything uummmm.....dont worry i will be back from fiji in time to have the 33 on the track.....
needs zorst, clutch, braided brake lines, servicing, diff
just need time and money
looking forward to this too!!
got some a1rm's fronts on the way, new swirl pot and pumps hopefully setup too, will be setting a lowish boost level and try do my best to stay out the way of you test pilots.
and he seemed so gung ho about it. what changed? oh well, for the better i spose, lookin forward to seeing more of blue32's impromptu barbecues! :D
Definitely.
yeah I recon lines have enough power and handling capabilities for the "Dustbowl" but braking is definitely an area that the Porsches have over us.
What?? I'm cooking the bbq?? :)
Ahhhhhh, thanks for offering Andrew :rofl:
not having a job at the moment is a killer.
-D
That's fine mate and completely understandable.....maybe next time. :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
