Ok guys, save for the people who have had to pull out, everyone has paid their deposits. Please remember that final payment of the other $100 is due by April 1st. This leaves just over 2 weeks. We are just under a month away from the track day so start prepping peeps, it will go quick!
  • Replies 846
Posted Images
whats wrong with your brakes dave?
i am almost ready for this track day, got my coilovers, a31 cefiro hubs and lower control arms, r33 gtst calipers and my motul rbf 660, all i am waiting on now is some brake pads and we are all set to change it all over :(
I need
Z32/R33 Brake Rebuild Kit
Braided Brake lines
QFM Pads
RDA Slotted Rotors
Some brake fluid
New rear tires
...and a helmet for the trackday. What brake fluid do people suggest? If the motul stuff, where do I get it and how much is it?
probably nothing. but everything can be improved. r33's are bigger, and r33 brembos* are bigger again. never a bad thing.
at the minimum im gonna run a rebuild kit through the calipers, machine the rotors, and bust out some new fluid. then ive got a basic service, do something about the fuel pickup to stop it surging, install castor arms and rcas, maybe run some brake ducting, fit a harness...
*and if i do pinch lukes brembos, ill need a bm44, and probably new lines.
Edited by scandyflick
well if you do pinch lukes brembos, i am always happy to help you out with the fitting & bleeding etc,
and aberax, as for the motul stuff, it seems to be the way to go, the going rate seems to be $50 per 500ml bottle, and unfortunately the only two stockists i have found are morpowa in modbury and autobarn
Cheers Bengi
Sled and myself picked up the motul at auto barn mile end for 27 and thats before club sponsorship
thanks steve, this is information that would have been useful to me last week lol :cheers: . is it the 660 that you got or the 600?
cheers Bengi
I would suggest Motul RBF 660 ~$55/500ml or Elf Lub HTX ~$40/500ml. I tried the Elf stuff last trackday and experienced zero fade throughout the day. I got it from AutoSports on Magill Rd and was given some discount.
I've also found Motul at AutoSports, Motorbike shops and Repco (on South Rd St Marys).
I doubt that would be the RBF 660. If so that is a great price!
Make sure u get 660 tho as the 600 doesn't work as well with abs :cheers:
I have been told this as well and my own experience with 600 was less than impressive (but I have no idea how long it had been since the brakes were last bled). When I mentioned it to my mechanic he disagreed and cited previous track records at Malllala with ABS equipped cars using RBF 600. For the next trackday I switched to Elf Lub HTX and thought it was excellent and about $15 less than Motul RBF 660 (going on RRP).
aww spewn was looking forward to seeing Adrians beast on track,
at the rate of everyone dropping out, i think we might just have to find a 25 for your motor for the day steve and whack you at the bottom of the list....and if we don't finish that just bring the camry
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
