i mentioned in the last post i made that there was another timer up fro grabs if people wnated it but i haven't had any response from that post. I'll take you off if someone want the spot.
Too easy
have u recieved my monies yet?
I've messaged Ruby to give me an updated list, still waiting but I'm sure it's gone through
  • Replies 846
Posted Images
Ok,
Can i get confirmation from these people that they still want the timers
(i don't want to be left out of pocket on this).
Aberax
Destroy
semislickR32
Tangles / writeoff (Share)
Scandyflick
BIT SUS
Krishy
4dr taxi man
HELSLO
Josh (What's his username)
Heslo
Heslo's +1
If people want to pay before hand them send me a PM and i'll send you my bank details.
confirmed.
how does the timing sheet work - old collingrove style (ie constant printout) or supersprint style (wait until all runs complete then get the goods)?
The unit that store the times is in the car with you and the signal is what is placed on the side of the track. The units will display the time as you pass the signal in big lettering and the best lap will be show at the top of the screen in small lettering. The units will store all the lap times which i will copy to a spreadsheet at the end of each session. people sharing the times will have to allow me enough time to copy all the times over.
sounds awesome!
only problem now will be setting some decent times...
Ok,
<snip>
still in.
wow thats awsome, well done :thumbsup:
I'll take one if it's not too late and if it's still availaible, otherwise don't worry about it.
your in, heslo your out.
Niksta you know they are $42 to hire and you'll be signing a form accepting the cost of replacement if it breaks? If so welcome to the party.
Agreed, thanks heaps
Not a problem Dale :P
I've amended the list with latest payments. Not long now guys!!!
While I'm at it. Big thanks to Roo for sorting out a little issue with Clem today, good work mate. Oh and guys, if you haven't got the money in by now, bring it on the day, DON'T transfer it electronically, it will not clear in time
Ok, so i'll try and be there about 8am...or just after. Thank goodness i am staying at Dion's place Sunday night, have less distance to travel.
Okay so we will leave mine at 7.45 to get there on-time :P
See, living in the ghetto does have a use!
Pussy :P I've got to be up at 4, to leave Golden Grove, take a mate to Craigmore to pick up Dave and his car, drive from there to Mile End for a Vilis breakfast, then from Mile End to Mallala. Make a day of it, enjoy it!
Okay so we will leave mine at 7.45 to get there on-time :)
May have to leave earlier...maccas breakfast run :P
I too would have to get up at 4am...if i were driving from Aldinga.I would like to be as alert and focused as i can be since it's my first time at the track, not wanting to damage my car...too much.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
