Hey there,
Not sure if anyone can help me or not.. My boyfriend and I recentley did the RB25det conversion into my r32 gtst. Im still having a few wiring problems and require both the R32 gtst & R33 gtst workshop manuals with wiring diagrams. If by any chance that someone has them just laying around and no longer wants them and wants to sell them or dont mind me borrowing them, I'd greatly appreciate it if you could send me a pm!
And here are a few photo's just for fun :thumbsup: I look freakin grubby as haha
Edited by Lady G
https://www.sau.com.au/forums/topic/303922-r32-r33-workshop-manual/
tried to wack it on here but its too big 23 MB wont upload times out .. shoot me a email addy i'll pass it over to whoever it needs it
I have R32 GTR and R33 GTST / GTR manual in PDF
P.S 32 GTR and 32 GTST manuals are totally different ...
Also have R34 Manual and V35 US Version
Judging by the fact you only have grease on the palms of your hand tells me you just rubbed them on some dirty parts for the photo shoot. :)
What wiring issues are you having? I can probably help you out.
:O I worked on my car! I had these annoying tiny scratches and bruises all over my hands so NERRRR :O lol
I have no idea on the wiring part of things. Ive left it all to my boyriend haha. He's an electrician so has a general idea but obviously cars and houses ae completely different so the workshop manual would be really helpful as he's done most of the wiring but there's a few things to be fixed up which he says the workshop manual with wiring diagrams will clear up for him.
Chris Rogers - I will send you a PM now :)
Thanks for your help! :-D
:) I worked on my car! I had these annoying tiny scratches and bruises all over my hands so NERRRR :) lol
I have done more than a dozen Rb25 conversion looms for the R32 so can help if needed. Happy to provide a plugnplay loom too if you don't want the hassle of doing it yourself.
Cheers
Ben
  • 1 month later...
Hey could some one pm me the R32 gtst manual and whichever other manual covers the mechanical for the RB25det as i have the same conversion in the car i just bought n i need them for the work im doing otherwise you can email them to me.
Cheers
  • Like 1
  • 9 years later...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
