Hi All,
Bought my 32 gtst a month or so ago and my rear left koni shock has blown. so im looking to get some coilovers as a replacement/upgrade from the koni shocks and springs. My car is primarily used as a drift car and to go up in the mountains... Its NOT a daily.
I was originally just going to get some second hand tein hr's for around $700... however they have been on a track car, and are old, and have no history, spares, tools, etc. and im not a close friend to this guy, so i dont know there condition.
So to play it safe, ive been looking into getting some brand new coilovers. The more expensive option obviously, but im sure more worth while.
So far im looking at these Teins...
Tein Super Streets with pillow ball upper (height adjustable, damper adjustable, camber adjustable, steel construction, etc.)
or
Tein Type Flex (more height adjustable, damper adjustable, camber adjustable, teflon and anodized so they wont rust) $500 more than the streets
or
Tein Super drifts (roughly the same specs as the flex's, but more aggresive i think) $600 more than the streets
My questions are...
Would it be worth me spending the extra $500-600 on the better coilovers? main reason being they have much more rust prevention, more adjustable, and are more aggressive.
What is the main differences between the Type Flex's and the Super Drifts? it seems that the flex are more all rounders, and the super drifts are more aggressive coilover.
Should i expect these coilovers to last a LONG time?
I just want to get some opinions and answers...Any other info would be good tho...
I havnt looked at much else but am open to some other options provided theyre not chinese shit!
thanks.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/
Hey mate,
Pop by TopPerformance in Vermont, they can rebuild and revalve your Koni's to suit any rate you want.
Choose come custom springs, Brown springs in thomastown will do a custom set of 4 for 260.
That would give you a decent setup, and would re-use what you have.
I have type flex, they are decent, But I had Koni's in my datto and they felt "nicer".
I assume you have yellows in the car?
You won't get coilover camber adjustment in a Double Wishbone car, this is only on MacPherson strut car, your front and rear camber is adjusted by your Upper Control arms.
-Ryan
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5038317
do they have to be tein? why do all skyliners think they have to use tein... look into other brands, hsd, n1 by isc, jic's heaps of brands tein aint the ducks nuts, also u'll need to at least get rear camber arms as skyline coilovers do not come with camber tops as rb_ryan mentioned. go for a 8 fr 6 re spring ratio.
i run the N1 coilovers 8-6 spring rate, very nice unit with base height dampening etcc.. and there cheaper then tein and before you say there Chinese do ya research.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5038456
Why do you need base height and damper adjustment?
Research would suggest all the brands you suggested are average :P
Teins might be better.
Koni's are at least easily rebuildable, working with what you have could prove to be the cheapest way to go, and easiest to rebuild in future, Koni's are well supported, not sure about other newer brands...
Bilsteins are far better in regards to reliability and consistency.
Ohlins, Sachs, Pensche, MCA,and maybe KW are another step up.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5038501
just fyi none of those coilovers have camber adjustment as it is seperate arm on r32 skylines as oppose to dirty s13's :)
definitely wouldn't go the super streets the spring rates on them are pretty soft for a primarily drift car probably would say the same about tien flex's
my greddy type s have 8kg front/6kg rear spring rates and they are just bearable on the streets so if it's purely a drift car/mountain runs try and get something like that or higher spring rates again
and also get aftermarket sway bars they will be your best friend for drifting
Edited by mystery_kid
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5039456
those rates and higher would be too stiff for vic mountains IMO. 27/24mm swaybars with 6/5 springs would be fine for drift IMO.
Have seen R32 drivers do fine without bars with soft coils in a 32, but i feel that swaybars would be worthwhile.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5039468
if it's just going to mostly be a track car you'd pretty much just go for as hard as you can get
Why?
Wouldn't you want a full package that works well?
You could get a custom stupid rate set of springs made, but thrown in with nothing else done they will make the car a slow bucket of shit to drive.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5039542
For the money i think you will be hard pressed to beat the Tein Super Streets. Been in plenty of cars running them and they are nice things. I used to run off the shelf Bilsteins and frankly they need to be valved by someone that knows what they are doing to be as good as the Super Streets.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5039565
Why?
he said it's going to be a drift car... he doesn't care about driving his gf to the shopping center
and i was also the first one in this thread to mention sway bars..
there is a bit too much throught going into this especially for primarily a track drift car imo
you want hard suspension basically.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5039642
Like i said, im open to other options, these are just the few ive looked at. but will look for some more now...
just fyi none of those coilovers have camber adjustment as it is seperate arm on r32 skylines as oppose to dirty s13's :laugh:
Sway bars will come after coils...
From what ive heard 8kg front/6kg rear is the way to go... but i dont want to go too hard. I'm unsure what spring rates are in the Koni's but they are too stiff for mountain driving, the car just bounces all over the place and looses traction and cant get power down(in a bad way).
yer i suppose
depends if he's leaning towards more track than mountain
Like i said... its used for both.. I want something that is stiff enough for drift and will also give me alot more traction in the mountains than these koni's.
Are we all agreeing on 8kg front and 6kg rear for the spring rates???
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5039906
No, 8/6 is too stiff. Been there, done that.
i'd be looking at around 6-7 front and 4-5 rear max. The higher rates would work ok with semis on a track. The lower rates are more appropriate for hills driving. it's a compromise.
Get some sway bars sooner rather than later.
Just a comment on the current setup. Make sure you don't have the rebound adjustment on the konis too high. It makes the car act like it has more spring and may contribute to your lack of rear traction. Konis typically have a bit over 2.5 turns of rebound adjustment. If you go past 2 turns the rebound goes through the roof. You want it somewhere between 1-2 turns.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5040120
Ive had ppl say 7/5 is too soft tho.... i suppose tho if i get 7/5 and get phat sways itll be fine for drifting.. and 7/5 will be better in the hills too..
Anyone in melbourne got a 32 with these spring rates(7/5) or (8/6)???
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5040389
Good discussion. I have the Tein SD's with spring rates of 7/5kg and 24/22mm swaybars. I bought them new and have had them for about 18 months. The car is still a daily but i attend as many Winton drift meets as my budget permits. If i had gone softer springs i would have run thicker swaybars.
Here's a video of the setup. (White 32 with black gtr bonnet)
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5041215
yeh looks alright.. but you can see it body roll a little bit.. not too bad tho
how does it go in the hills with those spring rates???
and how are the SD's???
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5041598
I have the front swaybar on soft and run the front damper pretty soft but that just suits my driving style. You could run thicker sway bars but i think they would be overkill with 7/5 kg springs. At the end of the day harder equals slower. The SD's are a bit rough for daily driving, but i don't mind/notice, as they come into their own at the track and they're awesome through the twisties. If you're looking at getting the SD's look into getting them from Japan as a $400-600 saving can be had.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5043319
hmmm... so youve got 7/5kg SD's with 24m sways... id probs run something like that or possibly 8/6 with the 24mm sways would be abit more suited to my car because its primarily drift, i dont drive in the hills too often.
how much did a set of SD's cost in Aus???
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5043394
Pretty sure my flex are 6/5, I wouldnt go stiffer for hills, welcome to come for a spin(guessing that was your next Q with your melbourne mention). Sways are a good idea. 27f, 24r selbys would match.
https://www.sau.com.au/forums/topic/304094-r32-coilovers/#findComment-5043565
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
