  • Replies 47
right i c
they all do, the apexi pen timer (the really pen looking slimline one) is about $180 i think is the cheapest i have seen.
why bother with brand on that man, stick it under the dash outta the way etc.
check with Mr Mayhem, he might have something japanesey in his garage
riaz is right dood its only a turbo timer just get something that is outa the way you dont need the name brands for that kinda crap....its just a money pit you just bought....nice ride and goodluck with learning to drive it....
it honestly took me about 3 weeks of solid driving to learn how to drive mine coming from the ford... :O
nice buy jennay!! :)
lol fane im still learning what my car can and cant do.... and ive had it about a month or so now.(taking it slowly, dont wanna push too hard when im not entirely used to her)..
my worst thing is i keep missin gears and grinding. (oh good son of rajab!) im slack with the clutch is all, tend to put it down a little bit rather than all the way.
but yeah, very nice lookin machine u got there
just be VERY careful... dont go thinkin u can do this that and the other cus u have had her for this amount of time an u think u know how to drive her. (sure, have a bit of fun. but nothing thats gonna get u or the car damaged in a bad way.)
just warning dude, cus u see all too many young drivers (including myself when i used to have a commodore) crash from tryin to do a burnout outta a roundabout, or rear end someone when i was drag racing. :)
You will definately cop alot of comments like "Daddy buy u a car did he" rarara... i know ive copped a couple like that.
Had one chick in maccas one day kept sayin shit like when we first walk in, shes like Ooo daddy buy you ya cars... (me and GTRRRR went in..both of which have P plates on the car :) )
then were sittin there and shes like sayin to her friend "cheap bastards, own a skyline yet they come to eat here rarara" i was like... oh my god.
but yeah... u learn to love it.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
