Heya,
So I had my rims changed the other day and with it a wheel alignment done. My car has been pulling really badly to the left.
Apparently there are 3 options in aligning each wheel but my R34 only allows one because of the suspension set up, which apparently you have to spend $ to have it changed. Is this right?
Once the alignment was done it was better but still pulls left noticably. They said it was also due to the poor quality tyres I have. I trust this mechanic but this is kind of annoying :D
Has anyone else experienced something similar?
Thanks
c
https://www.sau.com.au/forums/topic/304451-00-r34-wheel-alignment/
I am assuming they are referring to camber, castor and toe (which I would say either the toe or castor is out). Most cars will need to get a wheel alignment every now and again. My car has done this is the past but is usually fixed by a wheel alignment. I also think he means that with the standard set-up there is not much adjustment to be made hence why he might not be able to fix the problem. Without getting adjustable everything its hard to get it perfect.
Not sure how bad yours it...maybe something is actually broken and that's why it pulls to the left?
Hey Charli.
Camber and Castor are not adjustable standard. Look up adjustable camber arms and castor rods and you'll see that they do cost a bit.
Having said that, if adjusting toe (standard on all cars) doesn't fix you're problem then either something is broken or the bushes are worn. I'm guessing bushes are worn so you're probably better off getting adjustable stuff anyway.
Or you could (relatively cheaply) just buy the adjustable camber/castor kits from Whiteline - from everything I've read adjustable arms/rods lead to more issues in getting a perfect alignment (you need a really good shop) and cost more money, and are often defectable (rose joints) whereas adjustable eccentric bushes/etc do not suffer from these issues
I had a similar situation where my car (also a '00 R34) was pulling to the left, took it in for an alignment, but they said the issue was caused by a bad bush which was replaced and all ok..
I recall them telling me if the car is consistently pulling to one side it may not be an alignment issue if it makes no difference to the pulling whether you're braking, accelerating, cruising, doing mad drifts, etc.
Most mechanics could tell me that a watermelon is a suspension component and I'd smile and nod, though.
Hey Charli.
skylines have adjustable camber standard via eccentric bolts, just not alot, only enough to deal with stock heigh really.
This ^^ i did this because my cars low, and went n got camber+toe adjustable arms for the rear to get wrid of my tire chewing problem.
But first take it somewhere like pedders, if there is something broken they'll find it, might be expensive and "mainstream" but they do good work, and good allignments.
True. Forgot about that.
Whiteline stuff is a fair bit when it's all fitted too though. Probably better for a road car. I have it on my car at the moment but I'm going to rose joint stuff.
Thanks everyone, will investigate more... hopefully it will just be the bushes... the car isn't that old (km wise).
The steering improved a lot when they did the alignment but just not fully, it only pulls a bit now. Could it be partly because of the completely useless tyres they put on the car when it's imported? Or is that just fib?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
