-All drivers must be licensed (AASA or CAMS) and show licence at sign on.
aww damn this is 9 days before i get my p's and get my s14 back from my bro :|
Not sure about CAMS licenses, can't remember if you need your P's or not?
EDIT:: L2NS maybe?
  • Replies 271
Posted Images
ehh dunno bout the licenses, neway my 200 prob aint got enough power to get sideways anyway lol, non turbo and all.... but still would be good fun to go watch the cars i love do it :)
Doesn't matter man; if you can get your CAMs, GO FOR IT :nyaanyaa: we had a corolla wagon there last time... STOCK Corolla. Seriously, even if you don't kick it sideways, come, and have fun, and learn about your car. And then pop the clutch as you go around a hard turn :wacko:
ehh dunno bout the licenses, neway my 200 prob aint got enough power to get sideways anyway lol, non turbo and all.... but still would be good fun to go watch the cars i love do it :wacko:
Power does help when ripping skids, but not that much :nyaanyaa:
so do drivers need a helmet?
AS/NZ1698 or something compliant? Will look on my helmet when I get home. Is currently apart in prep of a respray :laugh: $0 to whoever guesses what colour it's being painted.
EDIT::
see the first post in this thread... The PDF attached; bottom of the first page. If you don't have one, there's plenty people who can point you towards a cheap compliant one (eg. Mine was about $100 inc. post and another two visors.)
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
