Scott fitted the Brembo brake package for me today, pretty much a bolt on affair with the calipers...used an angle grinder to hack off the dust shield in the rear.
350z Brembo calipers (F&R)
RDA slotted rotors
HPX pads
Stoptech G35 braided lines
the front braided lines had to be fiddled around with in order to get them fitted correctly and not hit/rub/scrub against the wheel. The rear lines fitted fine.
Bled the brakes and refilled with Nulan DOT4 fluid.
The Good: looks nice...brakes seems much grabbier when engaged.
The bad: brake travel shot to hell. In order to engage the brakes I had to depressed them fully or pump them. Scott thinks either a bigger master cylinder is needed, or a rebleed is needed.
Made an interesting drive down to Portsea tonight. Was pretty scared I was gonna stack...
Edited by ironpaw
  • Replies 129
Gets shorter. After a few pumps the brakes feel good.
As Duncan said...more than likely ableeding issue....I had issue's bleeding mine when I put em on as well. Took it for a test run with and on the second big hit they were fine.
I had no issues bleeding mine, these are a weird setup as the callipers run twin bleeders. Is there a particular method I should be using on the Brembos? We flushed the whole system and I bled each nipple until there was no bubbles, starting with the inside ones. Then I did them all again to make sure. Perhaps there was an air lock somewhere?
Hopefully any excess air has worked its way into the callipers, I will re-bleed the system for you tomorrow if you like.
your also supposed to either disconnect the battery or unplug the abs module
if you got any air in the abs you may also need to cycle it too (something that is done from the nissan diagnostic thingo)
craigs 'big hit' may have moved some of the bubbles from the ABS module to the caliper.
ironpaw, keep an eye on the front brake lines. one of mine moved and rubbed on the front driveshaft and started wearing out the braiding. so maybe double the cable ties
Scott rebled the brakes. Got a a couple more bubbles out. Pedal travel is pretty much similar to stock now...which is better but I'd think with all the stuff I installed the brake travel would be much less...
hmmm maybe I need to take a big hit with it...LOL
maybe a new master cylinder?
It's the total area that the master cylinder has to move that might make a longer pedal. Single piston calipers tend to have very large pistons. Best way to tell if the master cylinder is not OK is to measure the standard and new pistons and see how much larger the new ones are. Often the difference is minimal because it is the calipers that are larger not the pistons inside them.
And basically, bleeding after replacing everything can be a real PITA. Sometimes it is OK straight away, sometimes it will need a few shots.
A properly bled braking system should have a short pedal travel to get the pads to the disc, and then be consistent pressure all the way to the bottom. You should get the same feel on every push.
If it gets better after a pump or 2 you probably still have air in the system. If you get to the bottom and it sinks slowly you have a leak somewhere. If it is consistently long you have bled it OK and may need a larger master cylinder
nah......my peddle is perfect....doesn't need a new master cylinder.....if it's still soggy you still have air in the lines.....did you do rears as well? If not have you ever bleed the rear?
Scott rebled all four brakes.
Its better now but if I pump it the peddle feel gets better.
Found out on 350z forums that the master cylinder between brembo and non brembo 350z's are the same: http://www.350z-tech...ap-brakesmg.jpg
The difference is the brake booster?
is it even possible to replace the brake booster?
Danny said he never replaced his master cylinder but he didn't mention whether his peddle travel improved either....
found this: http://cgi.ebay.com/ebaymotors/06-Nissan-350Z-PWR-Brake-Booster-Master-Cylinder-R4376-_W0QQcmdZViewItemQQhashZitem43a4829cc4QQitemZ290522832068QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Edited by ironpaw
found this: http://cgi.ebay.com/...sQ5fAccessories
I am pretty sure Chris(Akebono) and Ben(Brembo) have not replaced there master cylinder or brake booster either.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
