  • Replies 211
Posted Images
No need to turn this into an R33 hate fest. :)
no hate fest here.... ive harpooned a whale before... let it go though.. best it could do was 12.01 1/4... just could not get it into the 11's, but then again, i had a gtr wang on it.... good for track work and cutting through the air around corners, not good in a straight line though.
drftin33.... you're different... the rest of us are mostly the same.
When you prove you've spend 50k, and have 250rwkw with a stock turbo...
maybe... just maybe... we might.
but i doubt it
hmmm when i ay 50k thats all up +te car its slef and when i say 38 grand i havereplaced evry thing under bonnet down to heater core al new tubing timing/+ the car was stolen at one time and i had to fix my kit and respary nelly evey panal and whn i say 250kw itht was wit last motor when i go it it had the dyno sheet and he said with stock turbo and i thout h new hat he was talkin about and we tested to down te1/4 male we put he bosst up to and finshedthe motor off i dont lie dude i will gt more pics when is back and i do own it
and btw wat wheel would you say for a skylin=p
what part of skyline yo want pics of gana take 2 days don have car atm
Dude, type normally for f**ks sake, we speak clear English on these forums, not txting your 10 year old boyfriend to come round for a quickie. Is it really that hard to type a coherent paragraph?
its not but my key board s stuffed when im typing noall my keys work :)
learnt t tipe plz k thx
I miss letters and make typos sometimes too... Do I just skip them and leave some abortion on the forums for people to step in? NO! I fix them...
One coherent f**king sentence from you would be great...
yea if you can be stuffed dont really have the time on my hands but ill try harder sorry :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
