  • Replies 1k
Posted Images
nope, they are pretty boring & i'll be in brisbane
Might go. Last one was a bit boring though.
phil- you doing any more tuning tonight?
Nah not tonight. Finished off most of Pav's S15 last night. Just going to go over the whole tune one more time to make sure everything is safe. Then I can grab the wideband for my car and finish it off.
I want my AEM wideband kit to show up so i can head out for a play with mine
I'll try and remember to ask everyone if there keen for a road trip to townsville. When my GF gets her new Polo GTI we want to go to Townsville for a weekend so that might be a good time, even if my cars not there
how has that been going? i've been following his thread on NS, i think you need to invest in a kmon and do a tuning course :whistling: and start making some $$$$.
i'll give you a call later to come & get that dvd.
Yeah most of the tuning is done on it. I havn't really seen his thread (got a link?). Will probably go out one more time and it will pretty much be done. A tuning course would be great just to learn all the little tricks that you can't really pick up on by yourself. Like for example getting a car with a Power FC to idle properly seems near impossible. There is simply bugger all settings for idle and it may be perfect one day but then crap the next.
Also I find the hardest thing about tuning a car is not the actual tuning itself, but the damn troubleshooting of a problem. I completely understand why workshops love tuning brand new Holden and Fords. All the parts are brand new and there is simply nothing wrong with the car. With 15-20 year old cars, gone through 4 different owners with parts ripped off here and there just leads to so many problems that take ages to narrowdown.
I will get a kmon eventually because I want to hard wire it into my car so it pulls timing upon detonation. Would be good to use on Power FCs aswell because I don't really trust those factory knock sensors.
Hey Phil what are you able to tune? Are you able to tune a nistune?
Havn't used Nistune yet. But I hadn't used a Power FC until two weeks ago and picked that up fairly quickly so don't see why Nistune would be any harder.
The guy who does my tuning is really good for this
Playing with timing and fuel he got mine from hunting randomly to running perfect at idle all day every day. Will be one of the things I quiz him about when we have a go at my car with the next mod I have planned
I need this fixed in mine again, I think cause of the lightweight flywheel its a bit funny at idle at times. I can see how that would be the case, taking a few kilos of rotating mass when the engine is at its laziest point
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
