So soon :O
Whats coming off first?
As much as I can take off on my day off on Wednesday :P
Are you building or buying, Phil?
Building man. Good time to build at the moment with the builders doing a lot of good deals and the government doing the extra $10,000 building boost until January 31st.
  • Replies 1k
Posted Images
I won't be riding shotgun with anyone for the Easter Cruise :P
i have manned up and decided to keep the car and go a high mount setup on e85
thats a better :thumbsup::whistling:
you can come down in my car and the girls can take the monaro.
if i have my way in the next few days i may have something pretty cool to drive down for easter :whistling:
Edited by robbo_rb180
Hey Phil, If you need a hand to pull anything apart let us know. Was alright Saturday, bit unorganised sorry guys. Definetly have to organise something for easter. Oh and Phil do Sau members get discounts :P
Hoping to order balancer, new boost gauge, wideband gauge in a week or 2, sump should be paid for this week pending ol' matey potatey takes the VVL head this week.
actually got some motivation to walk out to the gtr yesterday, removed most of hte loom from top section of motor, just gotta get under the plenum and remove the remaining connections and she's only got the "mechanical" things left.....
Might jack it up this week and look at the gearbox, apparently it's a push..... hoping it is................. LOL
Also may need a battery as this one has gone flat ( :( ) Phil, any idea what size it takes if yours and mine are hte same? (given you just went through this issue LOL) - Just need a size really as I'll probably get a optima.
Edited by Force Fed
Yep, I have a serious carbon whorism / obsession
Carbon pieces on the car:
400R front bar vents
Nismo B Pillars
Nismo Spoiler End Caps
Exhaust Shield (To be fitted)
Boost Controller mount / panel thingy
Spoiler Blade - Gotta modify
Nismo Gear knob
What's to come..............
Window control switches
Center Console lid
A pillars (drivers mainly but hopefully passenger too)
Bonnet struts
Eventually will get hte dash cluster done in PROPER carbon along with the sub meter as they are a "carbon look" from factory so proper will look legit.
and MAYBE get the air diversion panel done in it....
Is anyone an expert on 5 stud conversions...? Considering buying an s13 a in the middle of going through a 5 stud conversion but haven't done that sortve stuff so a little nervous ;) Phil you would know the car, a bloke by the name of Adam owns it out at mt low
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
