hey guys thinkin of puttin an vg 30 turbo in my 33 s1.5 do u think it would make much of a difference? would i have ot change many other thing make it run ok? also how hard would it be to install im pretty good when it comes to cars and stuff
I think it would be challenging to get 270 Kw's worth of exhaust gas through a VG30 turbine housing .
You can look at a VG30 BB turbo as almost an R33 one but with a slightly smaller compressor wheel and slightly larger ratio turbine housing . They were designed to be a basic low boost turbo upgrade for the 3 liter V6 hence the larger turbine housing for the same sized turbine .
Best performance option using std Hitachi bits is to exchange the turbine housing on the 33's turbo for the VG30 one . Largest turbine housing , 33's turbo already has the larger comp wheel thought the 34GTt may have a larger compressor housing , can't remember .
Cheers A .
The turbo i have on my car now did 260 on another car when it was first made.
By the time you rebuild it and spend the money on a hiflow you could of picked up a decent KKR turbo that would outperform it easily.
Have a search through the forums for KKR, they are junk, need lots of boost for not much power and they are very laggy.
You just posted what a VG30 Turbo can be described as, almost word for word.
Compared to a standard turbo? yes you could, now go off and read what people think of the kkr after using one and then compare them to the views from people using a vg30 rear housing, i can gaurentee you a lot more people are happy with there vg30 than a kkr, whislt you at it research what happens when you put bigger bits on your standard turbo to get more power.
No need to research, have owned VG30DET/RB20/RB25/RB26 powered vehicles before.
Thanks for the tip though bud.
I thought the VG30det's got a .63 turbine housing. If its true high flowing it with a Cropped TA34 turbine with 52T 76mm or a 56T 71mm comp wheel using a .60 comp housing and a strong actuator should crack just over 270rwkws.
Disco - the OP6 housing of the VG/R34GT-t turbo can get to 270rwkw off the GCG items.
That is probably the utter limit though, i've never seen anyone post a more powerful result, most come in around 260-270rwkw @ 20psi give/take.
So that would seem to be the limits reached.
A GCG hi-flow of a VG30 turbo is going to be out performed by a KKR turbo?
:thumbsup: That is... Impossible.
Well personally I think you're better off using a Garrett GT30 turbine housing because they are designed for a GT30 turbine .
Also only the ball bearing T series turbos use those TB31/TA34 turbines , the real GT28 or 30's use GT28 NS111 turbines or GT30 UHP ones .
All there really is to gain by using a VG30 turbine housing on a Garrett BB cartridge is the std position and format dump pipe . If you go aftermarket then there isn't any reason not to use an aftermarket one for the Garrett T housing .
Again personally I would not buy an aftermarket "VG" style turbine housing when there is Garrett IW ones available and designed to work with their cartridges and wheels . Also the Garrett GT30 housings are made of high temp resistant materials for petrol apps , not so sure about the aftermarket VG30 type thing . Also available in a range of sizes too .
Your calls , cheers A .
Disco:
Since we are talking about the turbine wheels and obviously your self works in the turbo industry. Would you think the Factory Garrett GT30 turbine wheels would out flow the TA34 turbines with crop for high flowing applications? The GT30 turbine is obviously lighter in weight and spools faster. Just have to go through the trouble of installing a custom shaft for sleeve bearing high flowing options.
Actually I don't work in that industry .
I think the GT30 turbine was designed to be low restriction for its ~ 60mm size and the largish 84 trim size and high inducer tips seem to be the way to go about doing that .
If you wanted something in the generic T3/small frame T4 shaft size you gould look into the GT32 plain bearing turbines . I think these are in the 64mm OD range and from memory the trim size is a bit smaller than 84 . I have no idea how heavy they are and I'd say they would be in lower temp spec material being a diesel turbo .
Cropping or back cutting turbine blades is one way of removing some of the restriction but its also removing some of the sail area used to drive the compressor wheel . Again from memory TA34 turbines went up to 76 trim which is what the street crowd call stage 3 .
Maybe something else to look at is the turbine used in the Buick Grand National , a long long time since I've seen one but if still available at least they are a Garrett petrol app turbine .
The problem as I see it is that bush bearing high flows are difficult to get right because wheels big enough to make adequate grunt are held back a bit by bush bearing oil sheer drag initially . I don't know if bush bearing GT series turbos are any better off in this area , maybe playing with a GT3268 or 71 cartridge could give the answer to that one .
Cheers A .
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
