Hi im from new zealand and recently i bought a r32 shell and i plan on dropping an r32 gtr engine into it. The one im looking at its imported from Japan and completely stock. I was wondering what was changed in the japanese engine to make it 276Hp so i could bring the engine to 320HP which the worldwide models came as stock.
Thanks
https://www.sau.com.au/forums/topic/306112-rb26dett-help/
"worldwide" model? The only R32 GTR that was released from Nissan was the 1000 GTR's in Australia in 1991 i think it was.
These horsepower numbers appear modest at first but stock RB26DETT engines have been dyno tested close to the 320 horsepower mark. The reason some RB26DETT engines put out 320HP and others don’t is due to environmental restrictions. In Japan, every production car is restricted to 276HP. Therefore, Japanese versions of the engine put out 276HP and unrestricted or non-Japanese versions put out 320HP.
https://www.sau.com.au/forums/topic/306112-rb26dett-help/#findComment-5065678
Actually the Japanese models put out "a nominal 276hp". This is the result of the law in place in Japan, which penalised cars producing more than 276hp. So the manufacturers declared their cars to only produce 276hp, even though everyone knew they produced considerably more.
https://www.sau.com.au/forums/topic/306112-rb26dett-help/#findComment-5066260
Also there was a small yellow restrictor in an air line that came on all stock RB26s. that limits boost/power on a stock engine to said 280hp.
when you remove that yellow thing, youll get a little bit more boost and more power...
https://www.sau.com.au/forums/topic/306112-rb26dett-help/#findComment-5069077
the nismo 400r which was 2.8 litre and had a stock rev limit of 9000 and 400 hp coincidentaly was advertised as 280 hp
at least you wrote the question properly and said thanks . it goes a long way . where bouts in nz are you . im in chch
https://www.sau.com.au/forums/topic/306112-rb26dett-help/#findComment-5069340
100 were delivered to Aus in 2 batches. 30 went to racing and 70 were privately purchased.
https://www.sau.com.au/forums/topic/306112-rb26dett-help/#findComment-5069653
hey im in the waikato area
https://www.sau.com.au/forums/topic/306112-rb26dett-help/#findComment-5071451
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
