  • Replies 259
How does it go in the wet? Well I only had it tuned on sunday and it's not a daily driver so... But it drives great normally, like any car, just control you acceleration. Car has a nice power curve so it's nice to drive.
why only 14psi, seems a waste of a good turbo :thumbsup:
Campbell
Need your advice guys.
My car is currently suffering from massive over steer due to KU36s on the front, and a stiff rear sway bar. My question is, do I fix the problem (put Kumho on the rear and upgrade the front swaybar), or should I just hit the skidpan as I am? I figure the wangs will be painful (and possibly dangerous!) but the skidpan could be a lot of fun, and the Supra will be very easy to flick around hats with the current set up.
Why only 14 PSI? Because it made 340 on that, and that is plenty for me... for now. I might only 2 or 3 more pound out of it anyway. If you are interested i can post you the dyno chart to show you that the turbo is being used quite well.
Can you adjust the swaybar to make it softer on the rear? and as Al said, just take it easy if you are not comfortable pushing it on the backtrack. Just make sure you are there for the 3.0L NA battle in the afternoon :(
sounds like fun. leave it as is. :(
you will get around the basketball court on the back track easy :D
Man up and drive the damn thing.
Drop your rear pressures right down for the wangs then put them back up for the skidpan. Of course you will need to take a footpump with inbuilt gauge because I don't remember seeing a compressor there last time :rofl:
Drop your rear pressures right down for the wangs then put them back up for the skidpan. Of course you will need to take a footpump with inbuilt gauge because I don't remember seeing a compressor there last time :)
Good way to fark up your street tyres and possibly have the tyres roll off the rim mid-corner :rofl:
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
