  • Replies 259
wtf straight cut gears in a pulsar?!
haha. what for?
Because of the power it'll be making shortly, what I use it for and the fact they shred stock gears with 100 less fwkw than it'll be making :laugh:
So, any experts care to give their opinion on the skidpan layouts? All I know is it looks like a lot of sliding and fun!
Last time I was there (in August) the Evo drivers were complaining that it was more suited to a RWD car, what's this set up for?
Also, that's my car in the footnote of the last page!
Bugger the EVO drivers :blush: jk
RWD, FWD or AWD it's all about you and your car and what you can do on the day.
I go for the fun rather than the competition and to learn to drive my car better.
Although it would be good to see a FWD win the day, one day.
Exactly Clive. I don't think I'd ever get near the top 10 but it's all in fun. A FWD came second many DECAs ago apparently.
Don't worry, I'm not concerned about winning or doing well. I'm going up to learn the car, makes some friends and have fun. I just find it interesting how people evaluate different layouts.
i've noticed that the event schedule says "Long Wang - Clockwise - 1st Run"
but the diagram lower down with the details of the backtrack events shows the Long wang as "Event 5, 7 & 9 Long Wang - Anti-clockwise"
I'm guessing its going to be run by the diagram, anti-clockwise
haha but it might be fun being a passenger coming for a few spins with you and a few others :P also wouldn't mind going in a 33 GTR to see how they go as i'm currently in the market for one.
Also cant wait until sat night we gonna have a couple of fishbowls or what davo :blush:
im not bringing my car, i broke my leg on my dirt bike a few weeks back :cool:
and yes, yes we are :(
Kieren did you get your super oversteer issue sorted out? :(
Yeah mate, running the same rubber all around and got a matching front swaybar.
It would've been a fun day though, if I survived the long wang.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
