2010 Sau Vic Renewal Bbq / Dyno Day - Sat 27 Feb @ Re Customs
  • Replies 160
I have an update for you all - THERE WILL BE PRIZES FOR MEMBERS!!! :thumbsup:
Most power RWD
Most power AWD
and each member will be entitled to vote in a Guess the KW's competition, with the closest the winner
The winner of each of the above will receive a $50 Supercheap Auto voucher curtosy of SAU-Vic.
(You MUST be a current SAU Vic member or sign up on the day to be eligable for prizes)
I have an update for you all - THERE WILL BE PRIZES FOR MEMBERS!!! :)
Most power RWD
Most power AWD
Hey Bec
can you bring me the trophy that i havnt picked up yet
will be there 100% on the day
This will prob be one of my few but fantical SAU-Vic appearances for 2010.
Hopefully someone will remind me closer to the date. Would be interesting to see what the 135i makes on the dyno. If it makes 50% of what the GTR made, I'll be mildly impressed.
It's 4 days away :)
Looks like I won't be the first one there anymore, as work hours has changed, but gonna come down in the afternoon :)
Still deciding on the 3 year renewal :P
Oh and if anyone wanna buy some 3M carbon fibre vinyl on the day, lemme know, I'll bring some down haha
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
