^^ +1
It's funny how ppl start to worry when the oil temps rise above 90 degrees C on a hot day, when it is considered normal.
Hot outside temps + A/C running (drains a little bit of power, so you put your foot down more) + if you drive hard / on boost = Temps will rise a little higher.
Just make sure you keep your oil and radiator levels topped up and you'll be fine.
https://www.sau.com.au/forums/topic/307354-32-gtr-oil-temp/#findComment-5077397
  • 2 months later...
mine has been most noticeable hot at a little less than 100 degrees, during travel at 100kmh and over 30 minutes.
about the Oil Temp Meter. I know it starts at 70 and finishes at 150. so does what make it 70 90 110 130 150 at each bar. Are these the numbers?
also when it got at this stage the HICAS warning light came on. whats that mean?
please bare with me: whats the oil temp for?
https://www.sau.com.au/forums/topic/307354-32-gtr-oil-temp/#findComment-5215213
GTRs come standard with an oil cooler...
They dont and even NURs dont come with oil cooler. Only N1s come with them.
Mine is always sitting at the bottom of the gauge (75?) when driving around and hottest is around 90+ I think during the SAU drag day which was in the midst of summer! Only did 4 runs though...
https://www.sau.com.au/forums/topic/307354-32-gtr-oil-temp/#findComment-5236129
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
