Hi guys,
just wondering what i would need to consider in terms of setting the susp for EC?
This suggestion was made - would you or wouldnt you? what other info is vital to help?
Front
Camber 2.7-3 degrees
Toe -1.5 each side
Castor 7 degrees
Rear
Camber 1.8-2
Toe 0
Not to sure what the above will acheive, i just drive the thing :blink:
https://www.sau.com.au/forums/topic/308077-eastern-creek-susp-settings/
I would probably run more camber on the front and Toe the rear out 1 to help under brakes. But what you have would be a good start and come in after a session and measure the temps across your tyres and look for any weird wear marks, then just adjust it so you like the feel of it.
Edit: I just read your sig a 1:05 at wakie and you are asking us for ideas, your way ahead mate good luck.
I'd go 4 degrees front camber and toe the rear end in 2mm total to help with stability on corner exit as a starting point.
pyrometer from there to see if you are using all of the tyre or just one side and adjust to suit.
Edited by badhairdave
I am pretty interested in peoples responses to this question.
Can you all please post up what you have actually ended up with on your cars? And what car it is.
I am keen to get results for R32 GTsT's
Edited by Tektrader69
Maybe if you could copy, fill in your details and enjoy :domokun:
Car:
Power:
Lap time:
Tyre and Pressure:
Front Settings:
Camber:
Toe:
Castor :
Rear Settings:
Rear:
Camber:
Toe:
From speaking to others on the forums - because i will not be running a r-compound tyre, i should ease up on the front camber as the tyres wont like it.
My biggest problem is i have no idea what all the settings really mean. The local alignment fellows set the car up for wakefield last time out, so obviously when going to EC, changes need to be made because its a totally different track. I have seen some info online but find it too rich to read when it explains the terms.
My level of experience at the moment is that the only honest results i can interpret from the car is that if it has a tough time turning into corners (understeer) or when the tail end is a little skaty. Once all the other terms are used or spoken about - its a totally different language. :)
Cheers
Steve
what tyres will you be running on?
what does the car weigh?
what power does it make?
what size sway bars front and rear?
what spring rates front and rear?
what's the purpose, superlap or an enduro race?
Hi Duncan,
sorry i cant answer accurately your request but i would like to thank you in advance, not everyday you have a seasoned racer comment :)
what tyres will you be running on? 285/30/18 yoko neova ad08
what does the car weigh? ~1500kg
what power does it make? 320awkw
what size sway bars front and rear? not sure
what spring rates front and rear? the suspension i have, have a standard spring rate at F8.8R8.8 although i am not sure because it looks likes the springs have been changed
what's the purpose, superlap or an enduro race? hopefully superlap
Cheers
Steve
Hey Steve,
As previous conversations it would be best to test the car at EC with the tyre of choice and a pyrometer.
I found that street tyres don't like huge amounts of camber on my car, but then again each car is different. Spring rates/valving will also affect camber settings.
Hope it all goes well.....
ok that helps a mile!
I'm by no means a guru but this is my ideas.....
first up....road tyres (even good ones). probably ok for 1-3 laps at a high pressure. after that you would be in trouble but at superlap that's not an issue.
compared to my car you make 100kw more and weigh about the same, but you have crap (relitively) tyres. and much harder springs and same or harder bars. its a gtr, right?
so....
less camber front and much less rear. your car will slide before it rolls up on the tyre too much. and you don't want much camber on the rear because it will lead to wheelspin.
front camber 2.5o, rear camber 1.5o or even 1.0o. Maybe .25o more on the right front
castor - as much as you can get without rubbing as always. 7o is heaps in a 4wd I am surprised you could get there without issues (then again r33 is much better at the front than r32)
toe front....I run 1mm out but I think that is a personal preference. I've heard of people running between 1-3mm out per side. More will be dartier (ie feel like it turns in better) but ultimately will have less grip IMHO.
toe rear....depends how much you like the tail to move. +2mm for very stable, +1mm for normal/neutral or 0mm for unexpected mid corner oversteer (can help with mid corner understeer for a flat out lap like superlap).
pressure...what tyres? assuming falken rsr or kumho ku36 or similar I would run about 40psi hot and check how it feels. Yes it is very high but it really helps in hard tyres, especially for only a few laps.
BTW no matter what with road tyres you will rip up your outside front. If you can take a spare outside front for the weekend and change it after practice.
also...just be stable in turn 1 (ie settle it early and keep it smooth), and be very patient in turn 2 (apex is the end of the ripple strip on the exit on bad tyres). don't fall for what you see the super taxis do it wont work on road tyres
Thats a tonne of info to digest :)
the only quesiton i have, is that this wednesday i'm due to go out to EC.
With Sydney getting drenched with rain and the possiblity of it raining on this day
is very high as well. Are there any wet weather tips i should consider?
I will definately keep you all informed!
Cheers
Steve
"pressure...what tyres? assuming falken rsr or kumho ku36 or similar I would run about 40psi hot and check how it feels. Yes it is very high but it really helps in hard tyres, especially for only a few laps."
Speaking to Gordon Leven race tyres, he told me optimum pressure on the Ad08 are 36psi HOT. I will gauge this throughout the day and have a play around as well
Edited by HKS26T
OK, so in regards to rear toe, i was under the impression that toe in, say 1.5mm+ was what was recommended for rear stability...so have i mis-understood?
so....
toe rear....depends how much you like the tail to move. -2mm for very stable, -1mm for normal/neutral or 0mm for unexpected mid corner oversteer (can help with mid corner understeer for a flat out lap like superlap).
Thanks Duncan and co for the input - these settings worked a treat today on the track! You are a GURU
Besides the tyres not liking more then 2-3 laps SUPERLAP CLUBSPRINT CLASS AGO GO GO!! :(
There is alot to say about my driving - but i wish to close the gap over the next couple of months
Now i know the car can go 1:45s (unofficially) Thanks Boz! A good driver is a couple of secs off a pro :P
So what time will i run if im just average?? :D
Edited by HKS26T
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
