Hey forum!!! As topic states I need a little help wiring the q45 throttle body to a series 2 rb25det. I already have the grey plug wired to the rb25 tps plug, but I am stumped as what to do with the wires that go to the black box on the side of the throttle body. A tutorial said to integrate into wiring but doesn't state how to. Can someone please explain to me what to do with the three wires that come out of that black sensor? Thanks.
https://www.sau.com.au/forums/topic/308397-q45-throttle-body-install/
There are two plugs on the TPS, one on the flying lead, and the other onthe TPS body.
There are two corresponding plugs on your loom. Simply plug them in. As per the tutorial you will possibly have to cut the loom to make things the right length and tidy things up a bit.
Wow you totally lost me. Let me tell you what I did. So far I have spliced the grey plug off the q45 to the brown plug off the series 2 rb25. Now I need to know what to do with the plug that comes off the black sensor of the q45.
There are a couple of threads around
This one might help
http://www.skylinesaustralia.com/forums/Q4...html&hl=q45
Ok do you see the picture in the link you sent. That grey wire I have wired up already, that part is fine. It is just that little black box that is on the side of the throttle body, I want to know what to do with the wires that come from there. That part I do not get is, the tutorial says to integrate the stock wires into the vq45 plug(with a pic of that black box above it). How do I do that? Can someone just say were to connect the wires of the plug that will be coming from the little black box. The grey plug is all wired up and everything is good with that.
http://www.skylinesaustralia.com/forums/Q45-T-b-t118484.html
That is the link to the tutorial I followed, just need to know what to do with the wires that come from the black sensor.
I asked the question on nico club .com, and I got a response, "you don;t need to worry about that plug. it goes to one of the big white plugs near the ecu that aren't used"
I have had mine Running with only 1 plug connected, it seem to run fine, but After 4 laps on the track, the turbo exhaust housing got way to hot and is now stuffed (warped).
Don't know if it has anything to do with how the TPS is hooked up, but that was the only thing I have changed and the car was fine before. :)
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
