ok so my standard turbo let go at 9psi sounding like a cop siren. got the boys at united fuel injection to have a look and found 1 of the impeller blades was chipped in the corner (attatched pic) caused by the internals failing (probably bearings) now before i put a new turbo in is that normal for a standard turbo to let go. usualy the turbo destroys itself or when it lets go its at 12+ psi so would there maybe be a problem in my oil lines or something? or is it just the turbo.
ok so to my original question. i rang up hypergear and im thinking of getting a standard highflow for $960 (240rwkw turbo using bush bearings)
-will it be safe to run this turbo on 9, 10 , 11 , or 12psi or however high i can go without the standard ecu hitting boost cut/rich and retard running an safc???
the car wasnt realy set up for an aftermarket turbo as ive still got the standard clutch, injectors, afm and ECU, the car made 192kw with the standard turbo before. ill be happy to run similar boost as before and make the same power (im not trying for 240 on my setup) just wanna make sure the ECU will be able to controll the slightly bigger turbo with steel wheels safely. cheers fellas
Edited by jimmys-33T
https://www.sau.com.au/forums/topic/308500-can-i-run-a-highflow-on-a-safc/
Aftermarket ECU all the way mate. Why do people try and cheap out on power increases in their vehicles? It only ends up costing you more down the track. Power = money and there's no way or loophole around that or everyone else would have done it already.
Yeah just run the same boost on the high flowed turbo. That should make 200-210rwkw, that should be fine on the standard ecu.
Then once you get some cash: injectors, fuel pump, nistune and clutch
Or you could just buy another stock turbo.
Edited by Harey
it depends what actuator is on the turbo
this spring is the minimum boost you can run on full load
if its got a 10psi spring you may find 10psi on a larger compressor wheel (as its a highflow) will be enough to trip out the ECU protection and cook the clutch
Good point, I forgot about the actuator. The hypergear hiflow i believe comes with a 14psi actuator so you definitely couldnt use that.
its the standard highflow for $960 not sure what he does with the wastegate ill ring tomorow and ask.
the reason i wanna stay with the safc is coz i dont have a spare $2000+ and i dont wanna make the maximum power possilble just wanna get it running safely will be happy with 180-200kw. just to get the car back running again im gna have to save every penny for 2 weeks and not go out at all lol.
im going for cheap and reliable, i can leave out fast for now haha
So just replace it with a R34 NEO turbo or something then?
Less than half the price of a hi-flow that you will never use.
i got the exact same as you, the high flowed turbo from hyper gear $960 one, im running 12psi fine before that, now that i got it in it spikes 14psi...and ever rarely cuts out...btw running a stock ecu also...but mind you i needed a fuel pump next day.
if i use a 34 turbo ill need a new dump pipe right? + i dont like to buy second hand parts about 80% of parts ive purchased have been dodgy in some way
as the person above this post said he was fine with it
-shudnt a boost controller stop it spiking? i dont really get what you were saying before about the spring being to tight and frying the clutch
yeh i forgot to add im running a 550hp walbro
The $960 high flow does not includes any actuators. We normally slot the factory actuator bracket 5mms down wards so you can add a little pre-load on it instead of 7psi, Depends on the pre-load that is on it. we normally sit them to around 10psi.
Other customers who bought 1KG, 1.2 KG or high pressure actuators will endup with higher boost readings. after all I would be expecting every one to run abit of boost through them.
Fuel pump, cooler, with high flowed turbo should have no issues running on 10psi with stock ECU. You can tab the CAS very slightly advanced on 98 fuel and get 200rwkws using factory map (do it on a dyno).
btw i was the guy who rang you yesterday, i sent the turbo your way earlier today.
so what your talking about with the wastegate having a preload of 10psi, does that mean 10psi is the minimum i can run ?
also wat do u mean by tab the HACS slightly ?
cheers
We don't have to pre-load it and leave it at 10psi. We can keep you bracket slotted so you can pre-load your self when needed. But once set it will be the lowest boost amount you can run. Also I meant CAS (Crank angle sensor). If you advance that by 2 degrees it using 98 fuel it will give abit more power, But test it on a dyno just in case engine pins.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
