Just curious to see wat other ppl out there use for there intake gasket side of things etc eg standard or tomei metals and whether u use any type of goop to seal better etc.
I used standard gasket on mine and have had a few issues with them leaking just curious to see wat other ppl have done
https://www.sau.com.au/forums/topic/308894-intake-gaskets-and-ur-opinions/
You'd be stoopid not to use a metal intake gasket set on a GTR. Any of the big name brands have good gaskets... HKS, Greddy Tomei etc.
I don't know. I've always found the factory Nissan stuff to be pretty good. Intake side is good from the factory and the exhaust side is great.
Not on GTR, its very common for the paper ones to leak , ive done about 4 this year already.
On gtst they are fine.
and youd be "stoopid" to say dont use metal ones on the intake wen u list tomei which make metal intake gaskets? :-D
yeh never had any issues with my gtst only gtr style stuff. ive done the good ole block of the front of the turbo trick and put compressed air into the plenum via a vaccum port and the amount of leaks that i found just little tiny leaks nuthin substantial but still. had 3 leaks on plenum to head flange as i run a hypertune plenum and 1 leak down on driver side cooler pipe. am gonna do the intake gaskets but was just seeing wat you guys would suggest instead of the paper nissan gasket if you had any success etc
If you have the TB's off do the main one too, another 10 mins. If you have the budget use a phenolic gasket between head and manifold then Nismo gaskets on TB's. I have some nice logged AIT data from winton with and without the phenolic gaskets and the intake temp is appreciably less.
What?
Re-read what he said....
"You'd be stoopid not to use a metal intake gasket set on a GTR. Any of the big name brands have good gaskets... HKS, Greddy Tomei etc."
Edited by Mr. Untouchable
What?
awwwwwwww yeh well guess im the noob now huh :-D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
