Just curious to see wat other ppl out there use for there intake gasket side of things etc eg standard or tomei metals and whether u use any type of goop to seal better etc.
I used standard gasket on mine and have had a few issues with them leaking just curious to see wat other ppl have done
https://www.sau.com.au/forums/topic/308894-intake-gaskets-and-ur-opinions/
You'd be stoopid not to use a metal intake gasket set on a GTR. Any of the big name brands have good gaskets... HKS, Greddy Tomei etc.
I don't know. I've always found the factory Nissan stuff to be pretty good. Intake side is good from the factory and the exhaust side is great.
Not on GTR, its very common for the paper ones to leak , ive done about 4 this year already.
On gtst they are fine.
and youd be "stoopid" to say dont use metal ones on the intake wen u list tomei which make metal intake gaskets? :-D
yeh never had any issues with my gtst only gtr style stuff. ive done the good ole block of the front of the turbo trick and put compressed air into the plenum via a vaccum port and the amount of leaks that i found just little tiny leaks nuthin substantial but still. had 3 leaks on plenum to head flange as i run a hypertune plenum and 1 leak down on driver side cooler pipe. am gonna do the intake gaskets but was just seeing wat you guys would suggest instead of the paper nissan gasket if you had any success etc
If you have the TB's off do the main one too, another 10 mins. If you have the budget use a phenolic gasket between head and manifold then Nismo gaskets on TB's. I have some nice logged AIT data from winton with and without the phenolic gaskets and the intake temp is appreciably less.
What?
Re-read what he said....
"You'd be stoopid not to use a metal intake gasket set on a GTR. Any of the big name brands have good gaskets... HKS, Greddy Tomei etc."
Edited by Mr. Untouchable
What?
awwwwwwww yeh well guess im the noob now huh :-D
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
