Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
it was part of my agreement with the other half that my car doesnt go for the sake of our first house. i dont mind mine sitting safe and sound while i work on the house (or bens car) once you move forward in life you realise that cars are important but they can wait.
that is precisely why my build is taking so long.. house + renovations = no money for poor old car = very sad me!
but i know its sitting there safe in the garage and noone is going to send us a letter saying we have to move out in 30 days.
Damo, with your dash.. how does it fare with time and working around it?? i started prepping the dash and was about to cover it when the mrs said i should wait and do it last, when its ready to drive again, as the suede may go shitty with the dash just sitting there and me working around it?? has yours degraded at all with activity around it.
update. pulled apart original sub frame removing all the all the arms ready to be cleaned and reassembled on the new sub frame. Found 3 out of 4 rose joints were beyond their used by date. these were originally Just jap arms and i thought that they would be impossible to get replacement joints for but turns out they are a commonish size and reasonably priced.
Note to self: this is not a "cheap" "Budget motor sport" Mod for your car.
worn rose joint/ rod end. the bras bush has worn and the whole lot jiggles.
next was onto making the new front LCA mount on the subframe. i got some 50 x 100 x3mm RHS steel and some 30 x 30 x3 angle to do the few mods. turns out working out where to put the mount and getting it spot on isnt quite as hard as i had first thought.
this is a prototype to see if i would even attempt making my own mounts
dont get to woried it wont look like that.
i also got some washers and drilled the centres out to be a snug fit on the suspension bolts so i could do this rear mod. the rear upper control arm is elongated to allow factory adjustment and this has a big heavy bolt designed to adjust the camber. to get rid of the bolt and to move the hole as far out as possible im welding washers on to the sub frame.
the pic shows the elongated hole from behind and where the washer will sit. if your concerned that 2 washers doesnt seem strong enough than have a look at the thickness of all the other pick up points.
this is the difference in bolts used for the job.
with a little luck on my side i will have a sample subframe bush made up ready for testing by the weekend and the diff will be back with a new ratio.
the suede will fade in direct sun light because its not of motor industry quality. mines not showing to much dust and dirt but being black it hides it well. if you want it to look all flash and new than id wait. depends how much dust is going to be in your car.
your assuming we measured ;)
We are going to mesure up our Targa R33, and copy that. It's just off getting stickered up at the moment.
For what? I didn't think you were running this year?
subframe mods look good. how did you end up measuring the front end of the LCA position?
as ben said im just going to take measurements strait off a r33 cradle.
thats the most ill be doing to this sub frame for now. i am worried about the amount of sticktion my LCA may have but ill rectify if nesasary.
Prototype bush has been made and going in for tidy ups on measurements tomorrow. should have completed units back by the weekend. lucky its a long weekend.
Damn I wish i had the know how of you guys... there is no way id touch any suspension mounts...the gamest i am is to fit camber arms.
So thats why im buying a set of slicks lol...ill get my grip the easy way
i take the oh that cant be that hard. and if it did brake or fail its only going to do XXX amount of damage.
when you see the size of the material and the the way its welded form the factory its not to hitec.
Great thread Damo! You guys make me want a bigger garage!
well its pretty cool having 1 car space for the car and 1 car space to make stuff for the car. but when the money jobs come in it all gets packed up. never enough room.
small update.
R33 stock turbo is on and all associated piping back on. only thing left to do was modify my screamer pipe as it was dumping onto the chassis rail.
now looks like this
ill give it a coat of hot pink in the morning. to tidy it up a bit.
and from underneath it looks like
it sits higher than the chassis rail so it wont be the part collecting ripple strips. keen to see if it changes the note.
i also like the look of lobster back thats why i dodgyed it up this way.
happy day.
got my sub frame bushes today and pressed them in and bolted the sub frame up to make sure its all going to work.
these are the Drift Mushrooms
and one pressed in.
they fit superb.
if anyones keen My machinist friend is happy to make these to order. :down:
definately better than pineapples but a hell of a lot of work to chuck in by comparison.
why leave the mushroom top so tall? free lowering....
the bushes go in backwoulds compared to the factory ones (push in from the bottom), so the frame sits hard agains the chassis. The excess is out the bottom to pick the nut up properly
go inspired today by reading other build threads.
Mainly thought that i owe it to fellow SAU readers to put more pics up ect.
Screamer pipe finished off and bolted on.
new stainless rear section added
top side of sub frame showing the drift shrooms and also the welded on washers for the upper rear mount to keep fixed position.
bonnet getting a revamp. welded up holes in bonnet. cut out more of the underside and tack welded the suport to the upper skin. going back to saturn black.
carbon cover made for over part of the wiring loom. just to tidy it all up a bit. anyone know where i can get a flatter front strut brace as my current nismo one looks way to high now
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
