Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
it was part of my agreement with the other half that my car doesnt go for the sake of our first house. i dont mind mine sitting safe and sound while i work on the house (or bens car) once you move forward in life you realise that cars are important but they can wait.
that is precisely why my build is taking so long.. house + renovations = no money for poor old car = very sad me!
but i know its sitting there safe in the garage and noone is going to send us a letter saying we have to move out in 30 days.
Damo, with your dash.. how does it fare with time and working around it?? i started prepping the dash and was about to cover it when the mrs said i should wait and do it last, when its ready to drive again, as the suede may go shitty with the dash just sitting there and me working around it?? has yours degraded at all with activity around it.
update. pulled apart original sub frame removing all the all the arms ready to be cleaned and reassembled on the new sub frame. Found 3 out of 4 rose joints were beyond their used by date. these were originally Just jap arms and i thought that they would be impossible to get replacement joints for but turns out they are a commonish size and reasonably priced.
Note to self: this is not a "cheap" "Budget motor sport" Mod for your car.
worn rose joint/ rod end. the bras bush has worn and the whole lot jiggles.
next was onto making the new front LCA mount on the subframe. i got some 50 x 100 x3mm RHS steel and some 30 x 30 x3 angle to do the few mods. turns out working out where to put the mount and getting it spot on isnt quite as hard as i had first thought.
this is a prototype to see if i would even attempt making my own mounts
dont get to woried it wont look like that.
i also got some washers and drilled the centres out to be a snug fit on the suspension bolts so i could do this rear mod. the rear upper control arm is elongated to allow factory adjustment and this has a big heavy bolt designed to adjust the camber. to get rid of the bolt and to move the hole as far out as possible im welding washers on to the sub frame.
the pic shows the elongated hole from behind and where the washer will sit. if your concerned that 2 washers doesnt seem strong enough than have a look at the thickness of all the other pick up points.
this is the difference in bolts used for the job.
with a little luck on my side i will have a sample subframe bush made up ready for testing by the weekend and the diff will be back with a new ratio.
the suede will fade in direct sun light because its not of motor industry quality. mines not showing to much dust and dirt but being black it hides it well. if you want it to look all flash and new than id wait. depends how much dust is going to be in your car.
your assuming we measured ;)
We are going to mesure up our Targa R33, and copy that. It's just off getting stickered up at the moment.
For what? I didn't think you were running this year?
subframe mods look good. how did you end up measuring the front end of the LCA position?
as ben said im just going to take measurements strait off a r33 cradle.
thats the most ill be doing to this sub frame for now. i am worried about the amount of sticktion my LCA may have but ill rectify if nesasary.
Prototype bush has been made and going in for tidy ups on measurements tomorrow. should have completed units back by the weekend. lucky its a long weekend.
Damn I wish i had the know how of you guys... there is no way id touch any suspension mounts...the gamest i am is to fit camber arms.
So thats why im buying a set of slicks lol...ill get my grip the easy way
i take the oh that cant be that hard. and if it did brake or fail its only going to do XXX amount of damage.
when you see the size of the material and the the way its welded form the factory its not to hitec.
Great thread Damo! You guys make me want a bigger garage!
well its pretty cool having 1 car space for the car and 1 car space to make stuff for the car. but when the money jobs come in it all gets packed up. never enough room.
small update.
R33 stock turbo is on and all associated piping back on. only thing left to do was modify my screamer pipe as it was dumping onto the chassis rail.
now looks like this
ill give it a coat of hot pink in the morning. to tidy it up a bit.
and from underneath it looks like
it sits higher than the chassis rail so it wont be the part collecting ripple strips. keen to see if it changes the note.
i also like the look of lobster back thats why i dodgyed it up this way.
happy day.
got my sub frame bushes today and pressed them in and bolted the sub frame up to make sure its all going to work.
these are the Drift Mushrooms
and one pressed in.
they fit superb.
if anyones keen My machinist friend is happy to make these to order. :down:
definately better than pineapples but a hell of a lot of work to chuck in by comparison.
why leave the mushroom top so tall? free lowering....
the bushes go in backwoulds compared to the factory ones (push in from the bottom), so the frame sits hard agains the chassis. The excess is out the bottom to pick the nut up properly
go inspired today by reading other build threads.
Mainly thought that i owe it to fellow SAU readers to put more pics up ect.
Screamer pipe finished off and bolted on.
new stainless rear section added
top side of sub frame showing the drift shrooms and also the welded on washers for the upper rear mount to keep fixed position.
bonnet getting a revamp. welded up holes in bonnet. cut out more of the underside and tack welded the suport to the upper skin. going back to saturn black.
carbon cover made for over part of the wiring loom. just to tidy it all up a bit. anyone know where i can get a flatter front strut brace as my current nismo one looks way to high now
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
