East Bear Gts-r Body Kit For R34 Group Buy
Yes, the speakers are plug and play to replace with something newer and better, as long as they have the same resistance and physically fit where the old ones do, I'd start with replacing them (because you will need to anyway) and if you still have issues will need to look into the wiring/amps/head unit (in decreasing order of likely to have failed). For bluetooth I've used Parrot kits for years, they wire directly into the speaker cables and give you bluetooth phone and music including good quality mic for the phone (I'm almost audible when using the phone over bluetooth in the stagea, which is a miracle). I'm sure there are other brands but quality of the mic varies and it is hard to tell before you install it
Drew up a aluminum bracket for my Haltech Platinum Pro ECU on CAD and got it laser cut. Took 2 prototypes to get the fitment right.
Update: I got the rotors turned by a local machine shop. This cured the squealing.
