  • Replies 179
hey guys..
count me in for this one..
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
11 - Melly R33 GTS-T
12 - Mag86 (Andrew) MR30 Ti (pending mobility /painkillers on the day)
13 - Luke R33 GTS-t
14 - R33_ACT (Rob) R33 GTST
15 - Michael R33 GTS-T
16 - Nathan R32 GTS-T
17 - David R33 GTST
18 - Dale R33 GTST
hey guys..
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
17 - David R33 GTST
18 - Dale R33 GTST
19 - Lee DR-30 rsx skyline If new engine is running
I don't know whats more scary.. the fact that he asked or the fact that you know
Used to detail cars, NEVER wanted to know what I was cleaning but carpet shampoo Usually gets MOST things out and if that doesn't degreaser works on most other things.
Did you guys actually plan anything for the cleanage of the cars?
I might be up for something provided I actually get my car back in time.
Would also appreciate any tips on good products for cleaning the engine bay. Not sure if I'm that motivated but just in case :blush:
Just use degreaser on everything (might want to put plastic bags over sensitive bits and clean with degreaser and a rag) and rinse it off. Don't do it while the engine is hot, but about 10-15 minutes after it's been off. Won't deform anything and the warm engine will dry water if it's gotten anywhere it shouldn't. Start the car once your done to ensure it dries out. After having it run for 5 minutes let it cool down a bit again and use a plastics cleaner (armorall sell a pretty cheap one) to spray everything with and start your car (again) to make sure it dries.
I don't like using water in the engine bay, do it at your own risk. I've had one car run a bit funny after doing it, I dried all the connections and after a while I got it back to normal, but I'm sure if you don't do this all while the car is warm worse could happen. I've detailed about 20 engine bays and only had one small and easy to fix problem. Not sure what other peoples experiences are. Just don't spray water on your engine while it's still at normal running temps. It will deform the metal. When I do mine and Shell's I'll be sealing the valley and doing that bit with a rag - Don't want water sinking down there.
Well I'm not going away this weekend anymore so
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
17 - David R33 GTST
18 - Dale R33 GTST
20 - Pat R34 GT-T
still meeting at the usual spot on saturday morning?
The event is on Sunday the 21st I think this is the 3rd time I have pointed it out in this thread!!
ITS ON SUNDAY!!!!!!!!!!!!!
Deep Breath :bunny:
I'll be there, but car will most likely be covered with bugs and other associated stuff as I'll be at the coast the day before. Unless I can be bothered giving it a good wash the night before.
Kat, we're using Damo's driveway in Melba... there's enough room for 2 cars in front of the double garage... but if you wanted to join us you could probably fit behind as the driveway is long enough :bunny:
Thanks chick, at this stage count me in. With any luck I'll get my car back in time :S
Edited by GTRKat
I'm going to be buying some stuff for me and Shell to clean our cars with, did you want me to pick up some stuff for you too? If so, just tell me what your planning on cleaning (e.g. Just exterior and engine bay, plastics, carpet). I've already got a bit of stuff left over from the last time I did this so I might not even have to buy much.
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
