You do not go to illegal drag meets, and try and paint a picture that things are "good".
The typical people taht attend such things are the kinda dumb idiots you see on Highway Patrol... it'll never end well.
If you wanted to paint enthusiasts in a good light, you would come to a sanctioned and legal event.
  • Replies 104
his pic said it all....ahhh is that a rabbit.... :)
Should he actually read the paper he works for....at all he would then know the hot spots for the kind he is looking for...
does anyone else feel strangely compelled to add him??????
maybe he should write a story about internet safety? At least it wouldnt be a waste of ink.
I can predict the title, "hoons are also internet pirates stealing all your personal information!"
I thought the age was better than this :)
F*** ya'll! Just because there's a controversial thread doesn't mean I have to offer up my opinion! So anyway...
I'm thinking this Ian fellow has gone about this totally the wrong way. But to be honest it sounds more like a troll than a genuine enquiry - journalists can be stupid, but who is stupid enough to throw a negative label over the people you want to speak to like that? Or perhaps he's actually doing a story on SAU and wanted to find out our reactions to such a question.
In the event that it is genuine...I'm sorry that you expected to find hoons here...we have a couple who aren't too bright (every car club does) but most of us are car enthusiasts. Future tip: don't call the person you want to speak to, a hoon. You might as well have called them a no good f***ing idiot. If I were a hoon I sure wouldn't want to talk to you. And I don't want to talk to you...so does that make me a hoon? Errr :)
I equate this to doing a report on serial killing and asking to spend a weekend with a serial killer, asking him to show you a thing or two by killing some people and then (assuming you survived the weekend) writing an article whinging about how much murder there is nowadays (read: you really are stupid).
If you want a real article that will get read then go against the pop-media grain and write something about differentiation of car enthusiasts from car hoons. Underground infiltration has been done to death.
Yeah. And lets not forget about the extra taxes Journalists have placed on lands that are an abutment of Church grounds....so yeaaah.....lets do it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
