Hey guys ive just bought my 2nd r33gtst im a bit lost .... its got a fair few mods it doesnt have a AFM so im guessing it has another computer running the show but ive taken a look and it still has the stock computer in the car or so it seems.. Is this even possible ?The car runs perfect just curious thats all. i can put up photo of the set up if that helps?
https://www.sau.com.au/forums/topic/310341-confused/
hey mate nah checked every where only can see 1 sensor near the throtle body ? literally checked every where under the dash so im guesing its inside the old case?Also is there usualy a vacume line running into the back of the computer i just noticed?post-71341-1267509904_thumb.jpgpost-71341-1267510009_thumb.jpg
Edited by @1dan
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5112784
that sensor looks like an air temp sensor so im guessing that there is an aftermarket ECU inside the standard ecu housing. probably something like a link g4 or a vipec.
check if there is a USB cable coming out of the ECU.
Edited by SECURITY
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5112989
If I didn't know the type of mangment system in a car I just bought... the first thing I would do is throw it on the rollers to check out the tune...
Make shure it's not running some "fully hecktic sick... timing"
J.
lol yeh thats a valid point.
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5113782
[haha lol im not some noob and i know all the parts on the car i was just confused as to wat could be done to the computer.. if i was missing something ... it has a gt3240 external gate plazman intercooler nismo injectors big fuel pump ect the only thing im unsure of is the computer... oh yeah also goes on the dyno this saturday just to make sure all is good
Edited by @1dan
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5114148
Ooh I don't know about that, a bargain is a bargain.............maybe thats what he had??
Anyway whats all the fuss about, a sub $1500 ECU, how many people here purchased their car to find some no brand aftermarket jap rechip or some such. I can't see any real difference TBH.
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5114263
Exactly right Security, as long as the price is right and the total package is good to go.........it only matters what you do with it after you got it that counts. So a check over and tune and and maybe a plan for what the car needs and what mods your looking at doing are the main points, not what happened before you got it. And if its no good then you wouldn't have purchased it in the first place hopefully.
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5114342
yeah thanks anyhow i actually dont know the last owner as it was a trade in at my families car yard he upgraded to a newer car...the car drives perfect and has been well looked after according to all the recipts in the glove box i have only had it for a week and have not had enough time to investigate every thing with work taking most of my time.... i guess only thing left to do would be to un do the stard computer and have a look in behind it.
https://www.sau.com.au/forums/topic/310341-confused/#findComment-5114393
    • Hi Apex and welcome!
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
