Ok today was suposed to be a good day, i got all my parts i was missing and i started cranking on the motor nice and early, but about an hour into it while torqueing one of the bolts to the rear main seal it snaps effortlessly. ok no big dead i have extracted tons of bolts, so i drill it out perfectly center and procede to use my extractor which than snaps in the bolt which is inside the block. i tried almost every bit known to man and nothing grabs it,, i bought a super expensive industrial bolt out but i cannot not drill into the old bolt out. the snap is flush with the block so i cannot try to grip it and take it out. my ONLY option is to drill and extract. does anyone know a good drill bit that i can use to get this out. i am soo f***ing mad i thought i was gunna slam motor on the hood of the chassis in a fit of rage. has this happened to anyone else ? i know better than to ask this, but has anyone else only used 5 of the 6 bolts that hold the seal in place. I am pretty sure only using 5 bolts would not be too bad. i looked at it and it dosent hold see any physical stress, and its rtv sealed. any input. after i messed around with it, i am sure it can onlybe extracted by a machine shop....
https://www.sau.com.au/forums/topic/310574-broken-stud-on-rear-main-seal/
good work breaking that one! I've seen plenty of main rear seal bolts stripped but normally the ones from the sump where they thread into the alloy rear seal housing. Anyway I'd probably leave it, if it leaks like a bastard some how (unlikely) you can always take the flywheel off and get to it in the car
I guess you weren't using a torque wrench...these are only m6 bolts right?
USA - do you have spark erosion guys over there? They seem to be able to get the impossible studs out..............not sure about ezi outs though, they are tough metal?
Otherwise a Dremel with some tungsten bits and be prepared to break a few, it won't be easy thats for sure.
Carbon tipped drill piece for drilling stainless, BUT you HAVE to drill freaking slowly (Like slowest speed possible!) or you will munt the drill bit.
Carbon tipped drill pieces are used on stainless and other very hard metals.
high speed dentst drill and a carbide bit or hers one for you weld a nut the same diameter as the origonal bolt head onto the shank,the nut will almost shutter the weld pool so it doesent contact the rest of the casting,ive done this many times before
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
