Hey,
I want to change the silly looking rubber inlet pipe, that goes from the AFM to the turbo. I have the stock air box in (cut out underneath), and want to keep it.
Are there metal replacements? Better rubber ones?
If it was metal I should be able to get some good cooler spool, yeah?
I have ebayed and googled but can't find anything :laugh: - except those blue silicone ones - any opinions on them anyone?
Thanks in advance for any help.
Bobby.
https://www.sau.com.au/forums/topic/310582-inlet-pipe/
yeh i've been trying to find one but i cant seem to find any... at the moment im using a metal intake pipe from autobhan88 or something.. there ok for highboost im currently on 17psi so yeh its not bad, but im sure you can get one customised
https://www.sau.com.au/forums/topic/310582-inlet-pipe/#findComment-5115955
Custom made should cost around $250
I agree. By the time you cost the alloy/stainless, silicone joiners, clamps, return pipe fitting and heat wrap, there wouldnt be much change left and thats not including the 2 to 3 hours spent on it, I know because I have been making custom inductions on the side for a while now.
You could just go to autobarn and make it up from their range if you want a bit cheaper, unless you can get mates rates from a fabricator like gfunkk. :laugh:
https://www.sau.com.au/forums/topic/310582-inlet-pipe/#findComment-5116166
the thing is you can get them custom made for about $100-$150 so no companies really bother making them, just take it to your local garage and say you want a custom one made
bahahahaha
Hospital grade stainless not the crap shops normally use. this included clamps and new silicon joiners
https://www.sau.com.au/forums/topic/310582-inlet-pipe/#findComment-5116357
If you want to make one and cant weld than its a combination of a 90 degree bend from the turbo then another 45 degree bend on the endof that and you can silicon joiner them together in the middle but yeah looking at around 100buxforall the parts
https://www.sau.com.au/forums/topic/310582-inlet-pipe/#findComment-5118503
As a guide. I just had a 3" piece of stainless made up with fittings welded on for BOV return and Breather line. Also had the pipe between turbo outlet and intercooler inlet remade out of 2.5" stainless.
I paid $140 (inc parts and labor) for both stainless sections.
So for the sake of it the rubber intake part would have cost roughly $50-60 to make out of a straight piece of stainless. I connected this up using 2 Silicon elbows (AFM side and Turbo side) they were about $60-70 ish each.
So to recreate this section in 3" / 75mm (this size suits my new turbo). Total cost about $200 keeping in mind I'll be installing it myself.
You will still need to add the price of reconnecting the BOV return and Breather lines, however price will vary exponentially from cheap hose to Braided line with suitable fittings so I wont mention this bit
Hope that helps.
Luke
https://www.sau.com.au/forums/topic/310582-inlet-pipe/#findComment-5118720
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
