hi there.
considering doing a nistune setup in my s2
I know for the s2 you need to get the ecu sent off to get the daughter board 'type 4' installed... then get it tuned...
am i correct in saying that nistune can do the following...
-Air/Fuel mixtures
-timing
-can you remove speedcut?
anything eles nistune is good for???
removing the need for an safc or sitc or similar...
s1 same as a 33 can have the z32 computer (turbo or no turbo what eva) modded to suit the s1 rs4... and done this way... slightly more expensive.
can u use nisstune for tuning to move to e85 fuel??? and what are the pros and cons of using e85??
are there any other recommended mods bar the following that should be installed prior to tuning the nistune...
-FMIC?? is it totally necessary
-3inch turbo back exhaust free of any bullshit :down:
-intake set up(again is it totaly needed? ive read that the airbox on stags is twice the size it needs to be b4 restricing (maybe a highflow panel filter??)
-boost controller (electronic of course)
-in a perfect world a bigger turbo would maximize the performance... and help fuel i spose with a slower wind up.
adam :)
https://www.sau.com.au/forums/topic/310675-the-nisstune-thread/
  • Replies 41
I am by no means an expert, but I have had the nisstune chip and tune done on my S2 and from memory it can also remove/adjust the rev limiter.
Also he said that it's good for tuning up to about 300 kw, 320 max. Can't remember exactly why but I think it was something like maxed out duty cycle. I'm sure someone else will be able to shed some more light.
As for mods, well I have a full stainless 3inch will metal cat (and a few other bolt ons) but the boost curve on my readout indicated that it could only hold 14psi till around 5k and then continued to dip all the way to the limiter. So a better/bigger turbo would yield much better results (obviously).
yes nistune can remove speed cut, well you actually set the cut limit to some ridiculous number effectively eliminating it, from memory the highest value is just above 500kph. Rev limit can also be adjusted, as well as the timing and fuel maps, of which there are basically two of each, one for normal conditions and the other is for when knock is detected. if you have an auto the timing used during a gear change can also be adjusted, handy to get a nice smooth change.
some of the more nitty-gritty tuning sections include, after start enrichment, pre-accelleration enrichment, dwell time and duty (for the coilpacks), idle speed, etc. most of which don't really need any adjustment.
couple other things you can see with the Neo stagea's are: the Boost Solenoids duty cycle, there is some head room to lift it up but not much, probably wont add too much more boost, but i have heard of people toying with using this output to control water/meth injection or even just a water sprayer system onto the intercooler. and there is also a large section of controls for the VVT.
i cant see any reason why nistune couldn't handle E85. doesn't E85 just need larger injectors to get enough of the fuel in. i'm running 600cc injectors on nistune with out a problem, its a simple rescale and check fuel mixtures, fine tune as needed. i'm also running a Z32 AFM on nistune.
with a FMIC, 11psi on the boost controller, full 3" exhaust system and a decent intake setup. just pulling the fuel mixtures back to a good AFR in nistune i had my stagea performing a lot better, the gain was really noticeable after a little tune.
Edited by QWK32
-Air/Fuel mixtures - Yes
-timing - Yes
-can you remove speedcut? - Yes
anything eles nistune is good for??? - As long as Matt (NIStune creator) has found the signal for the function, anhy function that is being controlled by the factory ecu, can be controlled via nistune.
can u use nisstune for tuning to move to e85 fuel??? - Yes, but you can't "easily" switch between tunes unless you have the individual software license. NISTune is not capable of storing more than one tune on the daughterboard at once. In order to run a tune for 98 again, you'd either have to get your tuner to put it back on, or keep a copy of your 98 tune on your pc and put it back on yourself.
and what are the pros and cons of using e85?? - Pro's: You can tune more power out of your car, before detonation kicks in. Con's: You use comparitively more of it than you do regular 98, so you often need bigger injectors/better fuel setup to cope with the increased demand.
replies in bold :down:
-3inch turbo back exhaust free of any bullshit :)
all of those would be great mods to have before a tune :rofl: at the very least, most people say at least a free(er) flowing exhaust before tuning a stag.
What's this about a series 1 getting a nistune using a z32 computer? I thought s1 stags were unable to get nistunes?
i think, but you'd have to check, you cant do it because of the auto controls in the ecu. i know the Manual R33 owners can do it with a Z32 or a R32 ecu. if it is possible it might be with the use of an auto Z32 ecu to control the stagea auto, can't say for sure though. email nistune and ask the question, Matt will know if it can be done or not.
thanx guys....
what is the procedure with the z32 AFM?? just get one a wire it in? not too hard??
whats it good for just more air passing through or is it better to tune with?
basically. but after wiring it up you need to make some alterations within nistune to get it to run. very similar to the way injectors are resized to work. with the Z32 it just gives you more resolution. a Z32 will allow you to run a larger turbo and boost (more airflow), where as the stock AFM will max out.
Edited by QWK32
the RB25 afm can only detect so much airflow. if you add more airflow (ie, more boost/bigger turbo), then you need to upgrade your AFM (Z32), or look at another alternative for measuring the extra airflow ;)
the RB25 one will get you a little ways yet though :thumbsup: your turbo will run out of puff first :laugh:
  • 1 month later...
anyone with a tuned nistune board in a S2 stagea want to give me there map??
don't want to get mine tuned atm as i need to do one more mod before i do, but i'm getting about 320k's to a tank if that !!
or even if you know what i can do to help with the richness of the map?
Thanks
curt
I have an s1 so does this mean I can get a nistune setup.
Q1.What is there web site WWW.
Q2.How much aprox.
Thanks
Phil
First of all no you cannot. As so far it has only been developed with the JECS ECU, 98 series 2 onwards...i believe..
2. Their website is www.nistune.com
3. Approx $400 +
^^^ very incorrect...
u NEED to ring jeff from speed lab... his numbers here somwhere...
it IS 300 for the board to be installed
and IS 300 to tune (depending on dyno time but that allows alot of runs...)
u can do it on an s1 with a z32 computer... u need to speak to him tho...
I was being very approximate. Is the z32 a stock series 1 computer? I was always under the impression it couldnt be done..
anyone heard anything about bikirom's?
i've had a few ppl tell me that they are better than a nisstune and have mapped out a lot more features of the r34 ecu than nisstune have
any thoughts?
Z32 and RB32 ecus plug into R33 Skylines but not into Stageas. You can make it work but unless you are good at wiring it is going to cost a lot of money ( I know, I've been there). My S1 now with manual box and Link ecu.
Thanks
curt
have you got a copy of the software Curt? what mods have you done to get such a low km per tank. the stock S2 map is pretty good till you put your foot down.
any thoughts?
Personally i think Nistune is the better product to have, and not because of the interface or the features its mapped, i cant comment on that as i have seen or played with the software, but because of the support base that Nistune has. Its only getting bigger and you will notice that more and more workshops are becoming familiar with Nistune. i dont think you can say the same for Bikirom.
If your worried about the number of features that have been discovered, i can assure you that there are more tables, graphs and values already mapped out than you will even look at. And with the owner of Nistune owning a R34 himself, if there is something that hasn't been mapped yet i'm sure it wont be long till its found.
Also something to think about, i got a Nistune board, installed by Nistune, and a single user software license for less than the price listed for just the Bikirom board on the Bikirom site.
cool beans, i think biki is pretty popular in qld and i dont think there is anyone down my way who tunes either (i do uni in tas but live in qld) so its gonna have to wait till i go home anyway
i would still like to hear from someone with a biki and why they went that way
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
