  • Replies 63
yes the r32 only has the rb20 which is a 2.0L whereas the later models get the 2.5L (although there were still some 2.0L versions). to be honest if you are just looking at getting a cheap first car, get a n15 SSS pulsar. it has the SR20 in it and the car is much newer than the r32 (by as much as about 10 years). insurance will be much cheaper as they were sold here by nissan, and parts are also much easier to get.
performance wise it would probably out perform the r32 gts (that is the base model, the gts-t is the turbo version) because even though it puts out fractionally less power and torque (although peak torque is 800rpm lower in the rev range), because the car is much lighter it will still perform well. i have one and it will happily tow my 3.6m boat on the highway and i can even overtake cars easily while towing. in fact one day i was able to pass a landcruising towing a 4.5m boat up a hill in overtaking lanes when he started slowing down due to the steepness of the hill. since you were looking at an ae111 you obviously aren't too fussed about whether the car is fwd or rwd which opens up your options much more.
you will find a tidy SSS pulsar for under $10,000 and there are plenty out there with reasonably low kms.
not true, ive got a non turbo r32 and its stock except a cat back exhasut, and i pull away from n15 pulsars....mines for sale if anyone's interested...
yeah probably the 1.6L pulsars. go up against a SSS driven by someone who is actually trying then get back to me. i've gone up against a natro r33 and beaten it in mine, as well as a stock turbo cefiro and beaten it.
nah way off bro ive raced my mates n15 sss with a sr20de...trust me i pull away...anyway im selling it for 6k with 168000kms on it...it needs a new gear bearing and a rear main seal...im gonna actually get that stuff fixed this or next weekend...the parts are cheap, but the labour ill cost a little...its gunmetal grey
lol you're so full of fkn shit, stop lying cause you're trying to sell yours!
R32 GTS couldn't pull the skin off a custard you douche.
This, i'd be suprised if an R32 GTS could beat a Subaru RX or a mirage/Lancer
  • 3 weeks later...
Hey guys,
I've lately taken a interest in Non turbo R32's. I was originally planning on getting a AE111 as a first car but my price limit is $10 000 and thats really pushing it for that type of car.
I just wanted to know if they are any good as a first cars? Usual things like: Reliability, Insurance, Fuel etc
I searched here on SAU and found a thread saying that they are known as GTS's, though I typed that in the keyword section of Carsales and only GTS-T's came up.
Also in the same thread someone said they are weaker than R33 and R34 NT's beacause it has a 2.0L so it needs high revs to keep it going.
Any owners out there please come forward with past good/bad experiences.
Cheers,
hey mate i hav a R32 with a RB25 engine in it this cars so dont listen to people when they say that R32 only come with Rb20s :) ive had myne for abt 1yr now iam happy with it oly brought it for abt 6k did a 1k RWC and i was back on the road. I havnt got insurance on it so i cant really tell u abt that. as for fuel i get around 300/400km per tank but all depands on the wy u drive.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
