ive got a question for everyone, i want to get a new car and have been looking at gtr's to replace my r34 gtt, now r34 gtr's are still out of my price range but i can comfortably afford a 33 gtr. now is it worth buying a car that is 3 to 4 years older than mine? because my parents say that im crazy buying a car thats older than mine.
from now on, you say "idears" whenever you referr to that car ok? turns me on. Sam, dude, thats just gay.
lol.
the whole thing reminded me of the time shan was going on about electric spider monkeys (sigged)
but really now, im no homo
OMFG finally finished the car and after 3 weeks its running again yay
things done:
painted intake plenum and rocker cover/coilpack cover from gay gold to crinkle black (managed to scratch 2 bits when putting it in but cant see it so YAY)
changed regular FMIC with hole cut under battery tray to return flow cooler. will be covering hole under battery tray
while most of the top was out and things along the side of the motor, went nuts with degreaser and now she has a oil and dirt free motor :happy:
one thing im happy with is that there is not a single bolt left over WOOT
next time think ill just pay someone to do it for me though lol
any tips on how to shift the rear caliper bolts on a 33? cant get a socket on there cos of suspension arms, and i've snapped my 17mm ringspanner on the bloody thing.
i have a pretty thick ring spanner. wanna give that a go???
dude if you can wait go for a 34. was in the same boat as you but 34 came out on top. better interior and new technology and its a newer car and looks 1 billion times better then the 33.
so yes your crazy. unless you love the 33s and cant wait to get a GTR and find a mint one
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
