yeah they wouldn't log the traffic as there is no interest in logging it and it's too much data to log constantly for every user
they only log traffic when you are intercepted, which is when you are under survelliance from the police for doing bad things
then your session / data is trunked to another a system which intercepts your session / data and logs it with full details
don't you have enough already mang?
Nah, just sold my NA MR2. ZX is for sale now.
If all goes well I should be putting a deposit on the newy in a week :huh:
It's quite possibly the girliest looking thing ever but with 260rwhp in a tiny car it will flyyyyy. That's pretty much stock too.
I'm waiting for the smartass commodore drivers to say "Why don't you let your girlfriend drive her own car?" and all that again. This time I'll actually be able to show them who's boss.. without trying ;)
is it a ford focus RS?
shoulda known it'd be a QLD when you started quote hp figures. Those guys up there love measuring in hp, suppose it's a bigger number than kW.
If you want I know a whole bunch of mechanics in Brissy/Goldy that can check the car for you before you commit.
But yeah, good luck with rego/roady. Interstate cars need to be inspected fully prior to rego. Tell your parents to take the car in for the inspection. If they see your lanky ass they'll tell you to go take the mods off and come back. Seriously, the inspectors are picky based on your attitude/appearance.
Thanks for the advice Shan. And I might take you up on that offer. I'll let you know really soon if I need it.
And no Justin, they didn't make auto MR2 turbos :huh: And clearly you can see the manual transmission in the pic...
nope. all they can see is how much and the charge. which is f**kign stupid but then again will be hard to record every download and page you went to. might be a privacy thing maybe???
but ye no way in hell im paying more then what i used. just went through my bill and it comes to $102 with GST if you exclude the data crap
funny thing is instead of resolving the issue they tried to up sell me to a higher plan and they kept doing it. so i stopped and listened and when they were done asked them if it will help me with my current bill? answer is NO. then why try and upgrade me? so it dosnt happen again. but it wotn happen again cause your f**kers f**ked up. oh rite lol
Because he wants to keep his job? :huh: LOL
Good to hear *shrug* looked like an auto style straight line shift thing
Can you blame them? 260 sounds MUCH faster than 193. :huh:
...and how long until ur off ur p's and allowed to drive a turbo again jez? Let alone a car that weighs 1100 kilos and has 193 kw?
And how often do you drive through Knox?
Youre crazy. Plain n simple.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
