heh, just makin sure you don't get all habib on us. otherwise we can't invite you to hang out with us cool kids anymore.
:action-smiley-069: so there is still a possibility of me hanging out witht he cool kids??? oh boy oh boy oh boy lol
there's an initiation process... a part of which involves jelly wrestling in a bikini with hamish.
bleck
tuff
4age + gearbox is in.... booked in for a wiring job @ adm.... should be drivable again soon!
what it set you back for wiring costs if you dont mind me asking?
ive gota get the 20v wired up, thinking of doing it myself, but its gona be a massive job haha
lol got given things to do and do a write up on a new system. the log on and password they gave me does no work and testers have gone home which means i cant do anythign till they comeback tomorrow morning.
so my write up so far is
1. system does not recognise admin username and password
LOL
woot i have 2 hours to kill yay
Jezz whats plans for you Supra?
Not a lot really. Just stereo and a few small cosmetic things. Getting alarm/keyless entry installed tomorrow and GReddy turbo timer :P
Had it sitting around the house and Lalin (from AI) said he'll install it.
Obviously the engine timer option is useless but I'm gonna use it for the digital speed display, 0-100 times, 1/4 mile etc.
Plus it looks cool :) Blue light will match my interior. Just purchased white/blue LED kit for the dash. The yellowy/green look is dated :D
Turbo timer in a N/A car...
I thought you were gonna get a MR2 Turbo?
What you gonna do about your 300ZX and I see you have sold the MR2 N/A...
I thought you were going to give it to your girlfriend?
Well it's really an "auto timer" as it says on the box. Says it works for both NA and turbo. As I said, I had it sitting around and wouldn't mind playing with all the features. Has got a volt meter and stuff on it too. So many useful features. The only thing I won't be using is the engine timer function :D .. Actually knowing me I probably will. Love seeing people's faces when I walk away and leave my car still on :)
Well the MR2 is sold (obviously, to cover the cost of the Supra). I didn't pull 15k out of my ass :P
The ZX... I dunno. Will most likely sell.
LOL!
Well if you really give your N/A a good thrashing, it's not a bad idea to let it sit for about a minute I guess...
I was going to say, why don't you sell the 300ZX and get something you really want... Unless the Supra is what you really want..?
i was at highpoint yesterday
toyota supra N/A in the carpark
FMIC core bolted in, no pipework connnected
awesome
LOL!
Highpoint is good for that shit.
Saw a Supra there all purple riced up shit...
LOL!
Well in my opinion when it comes to P plate legal cars, a Supra is a pretty good choice. When I want to overtake, power is only a down shift away :D
I'd love to go ahead with my ZX project but currently I'm not doing so well with money. If that picks up and my investments go well then I may keep the ZX. If not, Supra becomes my only car.
So your 300ZX is your current project car but on hold till your funds increase...
Yeah I have driven my friends N/A Supra.
3lt inline 6 with a Getrag 6 speed.
From memory I quite like that gear box as I recall it was very smooth.
Too bad he had all his stereo shit in the boot and weight a tone.
But now he has single turbo'd it.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
