Found a demotivational poster online last night. Was very sexist and something I would normally find funny BUT... the picture was of my girlfriend :cool:
If only I could find the bastard that made it... Grrrrrrrrrrrrr.
wats crakin folks, im bored
Got a new car yet?
get on it guys.
Fcuk Yeah!
LOL!
You gonna show us?
It's from a few years ago. She was on work experience. Would have been about 15.
And here is her now (the car wash pic that Shan mentioned) :cool:
Edited by jezza boii
I believe this is the ACA video.
awesome vid.... will do wonders for jap car reputatipon :P
Is it just me or is he gettin it all wrong ;)
http://www.facebook.com/profile.php?v=info&id=1193185305
