lol Shan, I like your thinking. Altho, you're wrong, cause me and my twin look pretty much the same & she is a chick :)
haha, tho I don't think she'd appreciate me posting her picture (and I won't be posting mine).
haha she's a quick one with the additional comment in the brackets. You know SAU too well.
in kris' absence in this highly rivetting intellectual conversation, I'd suggest he'd reply with something like:
Lolol shan. Sif talk bout epenis when you have the biggest. In person though you are quite the kitty cat
Jamie and Alex I know what I'm talking about :) no need to numb your little brains about it
Dw about shan. He likes to hit on most girls on sau lol. Not to mention has a slapping fetish. I'll let him explain that though
how much is that setting you back pat?
I went ahead with purchasing the best WMI system you can get on the market. You can get basic systems for $400AUD which use a an on/off pump to spray and work off boost pressure, but as we know boost tapers off at max rpm so that means flow of fluid gets smaller.
The system i got is a constant 160psi feed with a variable opening/closing injector. (same setup as fuel injectors with cars) and reads off injector duty cycle and boost.
I purchased it as there was a groupbuy, set me back $650USD ($720AUD)
Also need to throw in the water tanks, baffle, roll-over valves (dont want methanol spilling out when/if im upsidedown) and filters, so thats another $150~
SOOO looking at about $900~
haha.. cant wait to read the retaliation
shan your such an asshole.. :)
but then again. you remind me of those old guys that hate everyone and everything haha
lol Shan, I like your thinking. Altho, you're wrong, cause me and my twin look pretty much the same & she is a chick ;)
isnt that you in your avatar?. you have kinda posted a pic of yourself if so :P
goddamit... one time a chick asks me to slap her cos it turns her on, and suddenly i'm the bad guy.
wtf uleh.
i exist to hate on you. i'd go back in time and hate on your ancestors if i could. i'd even tell them off about their fail fitment 1hp cart.
its okay if you hate on me.
its okay if you hate on my ancestors
but it isnt okay to hate on our f**king cart
it had wooden spokes man
WOODEN SPOKES!
on another note: i wish i was around back then. dads grandfathers grandfather had a shit load of gold hidden somewhere. noone in the familys been able to locate it
Edited by GTR-boy
WOODEN SPOKES!
get digging boy. I want that gold now or I'll give you "gold" nuggets on your doorstep
thats what i was doing earlier last year when i went to syria lol.
searched half the land i inherited..
going again at the end of this year sooo another 2 weeks of searching haha
:) yeahh, im not gonna get myself into that little loop hole.
yeah, but having an avatar that tiny & it not showing my face is totally different to posting pics showing my face & stuff.
haha fair enough..
but you have your msn on your profile... so people could just add you there...
holy crap you got some mad drawing skills.
<stalker>oh and nice hip piercing :P</stalker>
Lol. When we doing another meet? Usual shit?
dog gets his shots tomorrow, so not tomorrow. maybe thursday? china bar does a decent hainanese chicken, so I'm in.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
