i like your work joeyjoe.
was the creator of that orange abomination referring to numbing my mind? it wasnt numb..just dumbfounded that stock suspension is better for getting 280rwkw down to the floor someone really should tell schumacher might get him another world champioship with that little pearl of wisdom.
Lol fag. I said it's better for acceleration than stiff suspension. The more the car squats the more traction you will get. Don't question my knowledge. I probably know alot more than you about these cars. Hey I've owned a 250rwkw r33 when I was on my l's (7 years ago) and p's thy had twin hr's. Handled awesome but no squat and ha no traction.
And just for your knowledge i have nothing againt Hamish and shan we actually are friends just tie eachother shit onthe interwebs all the time
man how do u walk with such a big e wang?
stock suspension is gay. dont try and justify it by saying u had a 250kw skyline on ur p'z.. mate i had a chrome mongoose so dont be fkn with me =\
your knowledge is rubbish if stock suspension is so great for acceleration why isnt everyone else using it? cos they could afford real suspension ?
hey my car has stock suspension still 0 to 100 in 4.88
is nobbad :)
...but far from ideal
the car would be quicker with suspension work
well mine has camber, caster, toe and pineapple kit
so still stock ish
your knowledge is rubbish is stock suspension is so great for acceleration why isnt everyone else using it? cos they could afford real suspension ?
Err I just compared my old 33 with tein hr's that cost like $3000 in like 2003. Awesome suspension for handling but didn't have any squat. Hence no traction. Thought i said that already but you must not have read that part. Obviously I can buy suspension anytime I want. But ot other priorities ATM than the car.
so u concede better suspension is better then stock suspension.
that was worth while.
of course it's better. But The suspension people buy because they have no idea and think that the stiffer the better. For now standard will do as it grips. I have taken it to skidpan days and it doesn't peform too badly. It's not an easy choice to decide if a car will be made for drift or traction. That the choice I need to make.
For record I did go to a skidpan training day. Thy had s14s with full drift setup and roll cage. I had my 100% stock suspension. Don't know if its the driver or the car but I performed slides on a wet roundabout all the way around. The s14 couldn't do 1 lap
For now standard will do as I blew all my money on a big fuckoff turbo, cocaine and bitches
fixed.
personally i'd rather get my suspension setup for handling before i worry about power.
not enough traction = get more contact area on the road = get your suspension right and run wider tyres (and run AWD :)).
saying stockies are awesome cos they squat is like saying the colour orange makes your car more aerodynamic.
umm, lol, thank-you shan? lol.. slightly creeped out now XD
just saw your devianart pics
you have skills!
the horse sketches are awesome. did you use charcoal to render or just normal pencil?
the cars proportions are a little off though :) practice makes perfect
the cars proportions are a little off though :P practice makes perfect
Are you saying my car is ''un-proportional''? :) :)
My silo was the first car she ever tried drawing, she does have skills, makes good coin too ;)
fixed.
Lol love the quote
Haha yea I am getting something soon hopefully. Just need to decide spring rates
Are you saying my car is ''un-proportional''? :):P
for a square car, yes it is :)
if thats a first try, she did a good job.
my first car drawings resembled integras with 48 inch chromies haha
for a square car, yes it is :thumbsup:
Haha, thanks, yep jesse's car was the first I ever had a go at, I can defs see where I went wrong with it ;). Both the horse and dog sketch things were done in just normal pencil, nothing amazing.
there's just no privacy on the internet huh! :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
