Have been thinking about what you guys said the other day.
Current plan:
- Sell ZX for as close to $6k as I can get
- Buy daily for $3k
- Sell Supra for as close to $16k as I can get
- Buy MR2 in Victoria. Modify it until I'm happy. No matter how long it takes or how much it costs
Does that sound like the way to go?
Might have to drop the price on the ZX again... It won't even sell for $6k. The market is f*cked now. I just want it gone though.
That style of rim has been and gone funky. Had the advan model 5's which look similar to that in 2003 lol
yes kris, thank you mr finger on the pulse. that's why these rims have been sold out across most of japan for the last month after being released in january this year.
shit's selling hotter than crack cocaine.
Current plan:
- Buy daily for $3k
sounds like the best revision of your plan so far. sensible at least, you've got a car you're passionate about and a decent car to drive around in.
word of advice, spend more on a newer daily that's prone to less faults/breakdowns. esp if you plan to build your MR2 slowly.
I'm sorry but why an mr2?
Just personal taste really. I love the unique shape and the fact that they're semi-convertible (targa top).
Mid-engine RWD in a fairly light car is also a great combination. The handling is very good.
Other cars just don't it for me :( Just like some people here prefer 32s over 33s or 34s. Beauty is in the eye of the beholder.
What would you suggest as a daily? I don't care how girly and embarrassing it is. I'd prefer a smaller car and good fuel economy is a must.
Mitsubishi Mirage? :)
Lol didn't say they looked bad
proton satria GTI, vw golf MK3, civic, micra, starlet... anything really that's small and sub 1.8L. the newer the better.
just sayin they're not as out of style as you may think. Also Advan 5's don't look like that nor do they come in that sorta fitment.
Cheers man :) That's a good list. I'll have a look on carsales now.
Do you know any dealers that would let me trade in my ZX? Would be so much easier than trying to sell to all these boyracers with no money.
offset :(
Lol should I post a pic of my car standard with the rims? It don't look too bad! The kit makes it look more fail offset haha.
Also where I live now I can't lower it anymore too :happy: I scrape to f**k going in the driveway and already getting cracks through the front bar lol
car is going in for another tune soon jezza. Getting a de cat put in and more boost. Need to also get it tuned a bit richer as it leans out quite a bit on very cold nights
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
