Would it be wrong to use an aboriginal word as a band name? For some reason I feel like I'm not worthy of using their language because I'm white lol...
Edited by jezza boii
what word do you want to use? im sure whatever it is it will be too hard to say and spell lol.
Alkira. I think it sounds really nice. It means "the sky". My music is inspired alot by the world around me (sunsets, beach, sky etc.) so the name really suits.
wtf... why do cnc'd titanium parts have oxidisation marks on them? that's full homo spec.
titanium + heat = oxidisation = pretty colours
titanium + electricity = electrolysis = pretty colours
titanium + cnc machine = mirror surface in a uniform colour
in fact to make a cnc'd titanium surface go magenta/green you have to etch the surface or subject it to extreme heat, which actually distresses the material and makes it weaker. This happens naturally near welds and shit, but on a machined washer and bolt? GTFO.
those washers are just anodised too look like titanium
i dont see any problems with it, i like it, easy to say and write lol. actually doesnt sound like an Aboriginal word.
id say go with it, you like it and it has a meaning to you and your music.
wtf is with all these shit sizes, harden the f**k up and find something decent.
I dislike the blue but thats personal taste, hate blue.
you find me epic fitment in 5x100 then. I'm trying to avoid running spacers, pcd adapters etc.
they come with 6.5 +30 or some shit.
After all the measurements I did I can fit 9" +25 to 9" +30 in the front with some rolling and so on. This will give me minimum offset on maximum width.
The rears aren't an issue, there's plenty of clearance and space to fit up to 11".
on the rear I'd like around 10" +25 or something like that.
this is the colour the car is atm.
Fucking euro's running gay bolt patterns and reverse mounting hubs.
That's not overly expensive.
Funky - do it right. eBay USA for some BBS's you know you want to!!
yeah i know its not
but atm for me it is haha
fuuuuuuuu
Might explain why my car has been trying to stall when coming to a stop yesterday
ive got a set of gtr injectors for sale :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
