ive had a review of the online demo i made for the hand controller
its actually pretty good i think, sure the format is ass, but the functionality is basic and works
http://www.paulr33.com/powerfc-emulator/menu.html
looking forward to someone doing it in flash and doing all the screens
fuuuuuuuu
Might explain why my car has been trying to stall when coming to a stop yesterday
nga wut? that's exactly what my ceffy's been doin... might check the injectors today.
Funky - do it right. eBay USA for some BBS's you know you want to!!
BBS's are cheaper out of germany, my uncle can get a set and send it down.
But I don't wanna just do a Euro/US spec BBS meshie replica. I want to give it that oceanic flavour. Like when I talk to the guys inthe US/UK they always go on about how we get work meisters and GT-C and XD9's on our skylines and shit... I wanna try and replicate that uniqueness.
I'm seriously considering a set of VS-XX's with gold centres in 9" and 10.5" front n back. However I'll need to run hub adapters for those, and that means I'm gonna be nervous as fuck about a wheel coming off, and also more importantly I'll lose up to 20mm of offset, which means I'll have to get like an 8 and a 9.5 or soemthing like that spaced out. Ideally I want something with max width and minimum offset that just bolts straight on.
And Basti's right, I'll never pay full price/retail for something, I'm happier buying secondhand. Otherwise I'd have gone out and bought a brand new golf instead of spending $5000ish on a 2000 model.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
