ive had a review of the online demo i made for the hand controller
its actually pretty good i think, sure the format is ass, but the functionality is basic and works
http://www.paulr33.com/powerfc-emulator/menu.html
looking forward to someone doing it in flash and doing all the screens
fuuuuuuuu
Might explain why my car has been trying to stall when coming to a stop yesterday
nga wut? that's exactly what my ceffy's been doin... might check the injectors today.
Funky - do it right. eBay USA for some BBS's you know you want to!!
BBS's are cheaper out of germany, my uncle can get a set and send it down.
But I don't wanna just do a Euro/US spec BBS meshie replica. I want to give it that oceanic flavour. Like when I talk to the guys inthe US/UK they always go on about how we get work meisters and GT-C and XD9's on our skylines and shit... I wanna try and replicate that uniqueness.
I'm seriously considering a set of VS-XX's with gold centres in 9" and 10.5" front n back. However I'll need to run hub adapters for those, and that means I'm gonna be nervous as fuck about a wheel coming off, and also more importantly I'll lose up to 20mm of offset, which means I'll have to get like an 8 and a 9.5 or soemthing like that spaced out. Ideally I want something with max width and minimum offset that just bolts straight on.
And Basti's right, I'll never pay full price/retail for something, I'm happier buying secondhand. Otherwise I'd have gone out and bought a brand new golf instead of spending $5000ish on a 2000 model.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
