you have my sympathy however...
i wouldnt worry to much about it, from all my breakups and shit the next girl ive been with was better than the last
there are plenty out there and i wouldnt stress about it, its over move on enjoy life
That's true, but I didn't break up with her because she wasn't good enough or anything.
This girl was amazing. She would do anything me, she was 110% gorgeous, career planned out and a heart of gold... but I just decided that at this stage in life I don't want to be held back in any way. I want to get serious about my music and career (which could be leading places soon).
I also lost alot of friends because I was seeing her instead.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :) Will be depressing sleeping alone and waking up without her.
Wheelspin in every gear except 5th. Yep, fun :)
Awww, I thought I was cool wheel spinning 1st 2nd and partially 3rd :) But mine is NA.. with like 125rwkw.
But hey, that power figure is huge. The power/weight ratio must be insane. How much does the car weigh?
I'm getting my new MR2 in a week or so. Weighs around 1150kg (with potential to shed more) and engine puts out 180kw stock. It's had a few mods (IC, fuel pump etc.) and running 15psi.
Should be pretty quick yeah? ;)
I'm not sure exactly, I haven't had it on a weighbridge. They weigh 1095kg stock. I'd say mine would weigh maybe 1150kg now? Just guessing.
Pretty good power to weight yeah :)
Your MR2 should be reasonably nippy.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :banana: Will be depressing sleeping alone and waking up without her.
i think you have done the right thing mate and in time you will realise that alot more. you need to concentrate on your career alot more for a few years like i have done and it does really help.
all the best with your career, by the sounds of it you will do well. :ermm:
dyno'd the golf at a mate's shop for shiggles. 80fwkw. bahahaha. POS 8 valve 4 cyl SOHC is gutless as. Does 8.5L/100km tho.
Also, factory paint flips from puple to blue, and in the dark looks black. Thing's gonna be a kent to colourmatch.
well turns out the evo has ghey as 1/4's, as much as they look wide you cant fit a 17x9.5 +17 on the rear without it sticking out about an inch
and aint no way im flaring them to suit
why make front guards that fit wider wheels than the rear O_o
oh well have to find something in the vacinity of 17x9 +25
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
