yeh thats what i saw when i looked
18x9.5 +20 rota grids
with a 20mm spacer on front its now 18x9.5 +/-0
and a 15mm spacer on rear its now 18x9.5 +5
ewww both these cars are running voltex widebodies, the rear quarter bolt on sections are shit as
:P this is the wastelandz you idjit. thread only ends when it get too big (approx 1000pgs) and funky makes a new one
i knooooooooooooooooooooo
miss the point much :)
yeh the te's are huge im diggin the bbs if u rock that stance though if u dont slam it like that will llook pox
why would u bother ? if u want stilts get some 4x2 from bunnings haha..
nah do it once do it right go baller cos most evo's fail that i see
haha they do, most run about what ive got now 8.5 +35 or 8 +38
the 9 +17 wil be a near perfect fit any wider/lower offset itll rub bad and i dont wana flare
get some adjustable coilovers and rise it higher, and then use it for what it was meant for and find some dirt tracks for some rally goodness :) .
i live on a dirt road, but i hate driving on it
i like clean cars, ive taken it down the road once it was soooo filthy afterwoods and dust was in everything.... never again
now snow.... thats a different story..... common winter :P
now snow.... thats a different story..... common winter :)
im the same, i hate hearing the stones flick up and you hear them hitting your car, it makes me cry.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
