mind you they're retarded when it comes to spending their hard earnt money too... I got top dollar for my TRD 2 way LSD, roll cage and XR4 wheels or whatever they're called.
anyways, speaking of shitheaps, a guy I know in the US just put some fibreglass on his Z31. I'm honestly in shock that this car is giving me wood.
LOL! @ AE86DC.
WOW!
For once a decent Z31, I would have mistaken it as a 180SX.
But take a closer look at the rear quarters, the Targer Roof and the rear pic of the tail lights... It's Z31.
Fuck that is good, not like the shit you see here in AUS or more so I am yet to see a decent one in AUS.
http://www.j-specimports.com.au/dealer/199...ON-3496634.html
not rare at all
edit: haha maybe it isnt
http://www.j-specimports.com.au/dealer/199...ON-3433768.html
edit: fark another one
http://www.j-specimports.com.au/dealer/199...ON-3369643.html
thought these are supposed to be rare :ninja:
they aint cheap thats for sure... but least the last one a manual :P
didnt know they were auto, i thouht they were manuals.
edit: ok you did find a manual one lol.
So I just lost 3 demerit points... The police officers "guessed" my speed by following me (from about 100m away) down a sidestreet.
Since when is that an accurate way to measure speed?!!
police have always been able to guess speeds
i got caught once like that to, was lucky i got let off though
They were nice cops... They said they'd let me off driving manual because the fine was so insignificant. I wasn't going to argue with them. I agree, I booted it into that street :ninja: Was trying to get the water off my car coz I just washed it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
