been a good week
tein s-techs
carbon exhaust shroud
red leds for the A/C controls to match the dash
and my titanium gearknob all came and fitted
few weeks wait on my wheels then tharaka going to give it a small shoot
hey funks where do you get your ultramarine paint from?
shouldnt any body shop do it?
need about 2 litres of it
fucked if I know, the boys at driftline source all my paint from some mob in campbellfield, they deliver tubs of it to the workshop.
alex... turning 29 in dec. insured with shannons since 25. no claims and a rating 1.
didnt you have a r34 gtt before? Im struggling enough with my r32 haha
no fair ;)
i started with a silver 4 door r34 that was non turbo then moved onto a black r34 gtt that i still have now (trying to sell it atm).
im definately not in debt or anything like that and im not one of those people where my parents bought me the car, and im not some stuck up douche either lol, just to clear some things up ;)
have you got much mods on your r32?
f**ked if I know, the boys at driftline source all my paint from some mob in campbellfield, they deliver tubs of it to the workshop.
i see.. must be that custom paint place
would ya beleive i only need 2 litres to finish off my project car?
bs shutup you stuck up douche GTFO ;)
yeh but yours is emo
now all your injectors are leaking ;)
haha new denso's are on their way ;)
im definately not in debt or anything like that and im not one of those people where my parents bought me the car, and im not some stuck up douche either lol, just to clear some things up :)
ah nice, great to hear its all working out for you
yeah ive blown a lot of money into my r32, just regular maintenance bits here and there. ~_~
Should have just quit and bought a lancer ey Nick :)
Should have just quit and bought a lancer ey Nick ;)
that makes sence, my first car i didnt buy anything for it just serviceing and than the gtt ive only bought a few bits and piece's so that definately helps with the whole money saving as well.
are you going to DECA next weekend?
