you're choosing to get 17" wheels (over 18" that you want) so that you can afford coilovers as well right now?
just buy the coilovers now, save a little more, then buy the 18". your car will roll just fine with the wheels its got on right now.
nah i liek the 17s to
ill get coilovers later on, but it needed low so i chucked in the s-techs for now
yeah... that's gonna happen. :)
my 32 was low with the coilovers, if i get them so will the evo
i'm skeptical of your definition of low. have you ever needed a sump guard for any of your cars?
my car is at nunawading getting complianced at import factory and i want to check it out so bad lol but cant, stupid work :banana:
import factory doesnt have the same dodgys running it as kamikaze does it?
oh so that was your car I was checkin out. sweet car.
had I known I'd have rubbed one out in the back seat as a congratulatory present.
thanks mate. well you can always do it another day :banana: .
does it look clean in person? ill have to see if the guys can take a few more pics of it for me to fap to lol. i dont think ill be able to check it out any time soon :banana:
Your way too scared alex.... driving around in that flashy car whinging about money, that can't be right haha
Work VS-XX 18X10 and 18x11 :banana: then ill show some respect :banana:
haha nah its not the cost but i gotta get rid of it in a year or less for tax purposes so dont wana go droppina bomb on it for such a short space of time.
prefer varianza to vs-xx
haha well not that low, was like 50mm at the exhaust
hopefully you dont drive your evo like this nick lol
haha seen that before
and nah wont wreck it :banana:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
